Til Salg Mondraker Chaser 29er 2022
Til Salg Mondraker Chaser 29er 2022 #2692092 17/12/2021 07:37
Registrert: Dec 2021
Ruiz Blanco Offline OP
FRAME:
Chaser 6061 Alloy Stealth Evo, e-Bike Optimized Zero Suspension System, 150mm travel, Forward Geometry, internal removable battery, Boost 12x148mm rear axle, tapered head tube, one-piece Monoblock upper link, HHG internal cable routing, MAX capacity sealed bearings, oversize 17mm axles, integrated dropout speed sensor, exclusive plastic motor covers, shock mudguard
Frame size
S: 380mm / M: 420mm / L: 450mm / XL: 490mm
SILENCER:
RockShox Deluxe Select R Debonair, 205x65mm. Settings: Low-speed rebound, air preload. Trunnion top mount, 25x10mm bottom bushings
Damper settings
Light compression, Light rebound, 1 Token
FORK:
RockShox 35 Silver TK 29, 160mm, TurnKey, Solo Air, tapered steerer tube, Boost 15x110mm axle, 35mm steel stanchions, 44mm offset. Settings: compression adjustment at low-speed to lock, rebound, air preload
HEAD COMPOSITION:
ONOFF Saturn tapered for 1-1 / 8 ”to 1-1 / 2” head tube, ACB sealed bearings, top 41×30.2x7x45ºx45º, bottom 51.9x40x8x45ºx45º
PRESENTATION:
ONOFF Sulfur FG 30mm 0º, 6061 forged alloy, 31.8mm barbore
MANAGER:
ONOFF Sulfur 1.0 double butted 6061 alloy, rise: 20mm, width: 800mm, 9º backsweep, 5º upsweep, 31.8mm barbore
GRIPS
ONOFF Diamond, 1lock-on, 135mm
SEAT:
ONOFF Pija dropper internal, diameter 31.6mm, S size: 387x125mm, M size: 425x150mm, L / XL size: 465x170mm
SADDLE:
PHYSICS Terra Aidon X5 145mm
FRONT BRAKE:
SRAM G2 R, 4-piston caliper, Centerline 200mm IS 6 bolts one-piece rotor, steel-backed organic pads
BRAKES:
RIMS:
MDK-HP1 29, 30mm internal width, tubeless ready, 32 spokes
TIPS:
CN round stainless steel
FRONT HUB:
Formula DC711, Boost 15x110mm, sealed bearings, IS 6 bolts
REAR HUB:
Formula EHL148 Boost 12x148mm, sealed bearings, IS 6 bolts
FRONT COVER:
Maxxis Rekon 29×2.6, tubeless ready, dual compound, EXO protection, 60TPI, folding bead
REAR COVER:
CRANKS:
Race Face Aeffect ebike, 165mm
CONVERTER:
SRAM X-Sync 2 Eagle 34T, steel, narrow-wide, 104 BCD
CHAIN:
SRAM SX Eagle, 12s, Powerlock
THROWER:
SRAM SX Eagle, Type 3 roller bearing clutch, cage lock, long cage, 1x12s, X-actuation 1: 1
ORDER:
SRAM Trigger SX Eagle, 12s, X-Actuation 1: 1, single click
CASSETTE:
SRAM PG-1210, 11-50T, 12p
FOOT:
Mondraker M068
DISPLAY:
Bosch Purion
ENGINE:
Bosch Performance Line CX Cruise (25Km / h) GEN4
FLASHLIGHT:
Bosch Powertube 625Wh
2022 Mondraker Chaser 1.jpg (197.59 KB, 164 nedlastinger)
2022 Mondraker Chaser 4.jpg (153.63 KB, 57 nedlastinger)
2022 Mondraker Chaser 5.jpg (161.8 KB, 36 nedlastinger)
2022 Mondraker Chaser 3.jpg (152.27 KB, 39 nedlastinger)
2022 Mondraker Chaser 2.jpg (185.37 KB, 38 nedlastinger)
Re: Til Salg Mondraker Chaser 29er 2022 [Re: Ruiz Blanco] #2692112 17/12/2021 08:56
anderfo Online
Begge annonsene dine er i helt feil kategori. Det er et eget underforum for salg av sykler:
https://www.terrengsykkelforumet.no/ubbthreads.php?ubb=postlist&Board=55&page=1
Re: Til Salg Mondraker Chaser 29er 2022 [Re: Ruiz Blanco] #2692719 22/12/2021 22:25
sindrer Offline
Størrelse og pris?
Sindre R.
