Scott e-Genius 700 Tuned - XL - 2018
Scott e-Genius 700 Tuned - XL - 2018 #2590190 05/02/2020 12:12
Registrert: Jun 2005
Heliboy Offline OP
The Photographer
The Photographer
https://www.finn.no/bap/forsale/ad.html?finnkode=169617287
2018-mod, rammestr. XL. Toppspekket fulldempet råskinn med 150mm vandring, selges med ekstra batteri og ekstra lader (nytt, verdi 7000 kr). Elektronisk Di2-giring +++. Nypris var 91.000 kr. Brukt 40-50 turer. Scotts geniale lockout på demping, Shimano Steps E8000 motor (fjernet fartssperren med SpeedBox). Akkurat fått montert nye krankarmer (10mm kortere, for mer klaring). Det ekstra batteriet kan man f.eks. ha i sekken, noe som gir en helt enorm rekkevidde. Batteri byttes i en fei. Blir din for 45.000 kr
Fulle specs:
Product Scott E-Genius 700 Tuned E-Bike
Model Year 2018
Riding Type Enduro / All-Mountain
Wheel Size 27.5+
E-Bike Class Class 1: Pedal Assist (Pedelecs)
Motor Shimano Steps E8000, 250W
Battery Shimano BT-E8010 with charger (erstattet med E8020-ladere)
Battery Capacity 500 Wh x 2
Display/Remote System controls and power modes are accessible from handlebar actuated levers and Shimano display. Display screen: battery level indicator, gear position, assist gauge, assist mode, and display mode (distance, odometer, range, travel time, current speed, average speed, max speed, cadence, watts, calories, or clock)
Modes Eco, Trail, Boost, and Walk
Frame Material Aluminum
Frame Material Details 700 alloy with internal cable routing
Rear Travel
Descend:150mm
Traction Control:100mm
Lockout:0mm
Rear Shock FOX Nude EVOL, Trunnion mount, Kashima, TwinLoc Remote Technology, 185mm x 55mm
Fork FOX 36 Float Factory Air, Boost, FIT4 damper, Kashima, TwinLoc Remote Technology
Fork Travel 150mm
Head Tube Diameter Tapered
Headset Syncros FL1.5 Press Fit E2
Handlebar Syncros FL1.0 Di2 Mini Riser, carbon, 740mm width, 12mm rise, 9° sweep
Stem Syncros FL1.5, alloy 2014, Garmin mount, 50mm length (S-M), 60mm length (L), 70mm length (XL), +/- 6°, 31.8mm clamp, integrated spacer and top cup
Grips Syncros Pro Lock-on
Brakes Shimano BR-M640 Zee with 203mm Shimano SM-RT64 CL rotors
Brake Levers Shimano BR-M640 Zee
Drivetrain 1x
Shifters Shimano XT SW-M8050-R, 11-speed
Rear Derailleur Shimano XT RD-M8050-Di2 SGS DM Shadow Plus
Chainguide Scott
Cranks Shimano STEPS FC-E8050
Chainrings 34 tooth
Pedals None included
Chain 11-speed
Cassette Shimano XT CS-M8000, 11-46 tooth, 11-speed
Rims DT Swiss H1825 Spline CL, 30mm width, 28 hole, tubeless ready
Hubs DT Swiss H1825 Spline CL, Boost front and rear
Spokes DT Swiss
Tires Front: Maxxis Minion DHF, 2.8" Double Down Maxx Terra TR 120 TPI kevlar bead
Rear: Maxxis Minion DHR II, 2.8" Double Down Maxx Terra TR 120 TPI kevlar bead
Saddle Syncros XM1.0, carbon rails
Seatpost FOX Transfer, Kashima, 100mm (S), 125mm (M), 150mm (L-XL)
Seatpost Diameter 31.6mm
Seatpost Clamp Standard
Rear Dropout / Hub Dimensions Boost, 12mm x 148mm
Bottle Cage Mounts
22.9 kg
Medfølger 3" piggdekk.
Noen bruksmerker her og der, så klart, men jevnt vedlikeholdt og alt fungerer som det skal.
Løvsteika
Re: Scott e-Genius 700 Tuned - XL - 2018 [Re: Heliboy] #2591246 14/02/2020 14:22
Heliboy Offline OP
The Photographer
The Photographer
SOLGT!
Løvsteika
