2019 RockShox Lyrik RCT3, 27.5"/29", Solo Air, Boost™ 15x110mm, 180mm. Ny og ubrukt selges i begynnelsen av januar.
Veiledende pris 10500,- selges for 8500,-
Specs
Specifications for Lyrik RCT3 15x100
TRAVEL 160/170/180mm - 27.5" , 150/160/170/180mm - 29"
WHEELS 27.5", 29"
AXLE TO CROWN 572mm - 27.5"/180mm travel, 571mm - 29"/160mm travel
WEIGHT 2005g - 27.5" , 2032g - 29"/27.5"+
DAMPING Charger Damper (RCT3)
AVAILABLE SPRINGS Dual Position Air, Solo Air
ADJUSTMENTS External rebound, low speed compression, 3-position compression (Open/Pedal/Lock)
STEERER OPTIONS Tapered aluminum
UPPER TUBES 35mm tapered wall aluminum, Fast Black
https://www.finn.no/136741203 for illustrasjonsbilder.
Kontakt Mats på 90867074 :-)
