29 Rock Shox SID RL kr. 3000,-.
29 Rock Shox SID RL kr. 3000,-. #2493166 22/06/2018 12:13
Registrert: Apr 2016
ahs Offline OP
Satt på ny sykkel og hatt ett par turer på den. Meget pen og strøken.
Kjøpt høsten 2017. Svart. Kan hentes i Oslo. Send PM!
Travel: 100mm
Wheel size: 29"
Spring: Solo Air
Damping: Charger 2 Damper (RL)
Adjustments: Lock out på krone, External Rebound, 2-position compression (open/lock), Air pressure via common Schrader valve
Steerer: Tapered 1.5" to 1 1/8"
Steerer length: 180mm
Upper Tubes: 32mm
Disc brake mount: Post Mount (PM6 - Direct Mount 160mm)
Maximum Rotor Size: 203mm
Drop out: 15x100 mm Maxle Lite
Offset: 51mm
SID RL.jpg (1000.42 KB, 313 nedlastinger)
Redigert av ahs; 22/06/2018 12:15.
Re: 29 Rock Shox SID RL kr. 3000,-. [Re: ahs] #2493285 23/06/2018 09:42
ahs Offline OP
Solgt!
