Strøken Rock Shox Monarch RT 184x44mm
Strøken Rock Shox Monarch RT 184x44mm #2492897 21/06/2018 13:37
rage Offline OP
Som ny og strøken Rock Shox Monarch RT selges, kun brukt 5 timer. Tatt av en Kona Process 111 2017, MED tune- se bilde.
Selges 1500.-kr inkl. frakt
Specifications for Monarch RT
WEIGHT 215g
DAMPING External rebound, 2 position compression (Open/Pedal)
CONFIGURATIONS 184x44mm
REBOUND DAMPING Rapid Recovery
SPRING Standard, High Volume, Standard with High Volume Eyelet, High Volume with High Volume Eyelet
SPRING ADJUST Air pressure via single schrader valve
SHAFT MATERIAL 7075 aluminum
SHAFT DIAMETER 9mm
BODY MATERIAL Hard anodized, forged aluminum with sag gradients
BODY FINISH Fast Black
UPGRADE over R: Threshold
Re: Strøken Rock Shox Monarch RT 184x44mm [Re: rage] #2493431 24/06/2018 19:54
rage Offline OP
Solgt.
