Som ny og strøken RS Pike RC Solo med Air Vorsprung Luftkappe 29 140mm 2017 modell selges, kun brukt 25 mil iflg Strava. Service tatt okt 2017 på VPG og kjørt max 5 mil etter dette pga kragebensbrudd. 17,5 cm lengde kronerør/ tapered/ Maxle Lite 15mm. Gaffelen er smude smud. (Lik den på bildet men i Stealth- utførelse, matt svart med blank svarte orginale dekaler)
Selges 3000,- el høyeste bud.
A comeback has never been so amazing. After taking a few years off, PIKE comes back in the RockShox line-up, as the ultimate trail fork. Your trail could be a silky smooth ribbon of singletrack, or a rock-infested goat trail in the Alps. Either way, there is a PIKE for you.
Features: Spring: Solo Air Damping: TurnKey lockout Adjustments: External rebound, low speed compression, 3-position compression (Open/Pedal/Lock) Steerer: Tapered Aluminium Crown: Forged, hollow 7075 Aluminium Lowers: Magnesium, disc only Axle: Maxle Lite 15mm Maximum Rotor Size: 200mm Weight: 29” – 1876g (4.14lb) NB: Does not include pump, seal kit or star nut.
Technologies: Air Guides: RockShox print Air Guides on all of their air-sprung forks. Maybe not a technological feat, but it will help you set up your suspension in seconds instead of minutes. And more time on your bike equals more chances to earn King of the Mountain on your favourite trail. Maybe they are a technological feat. Charger Damper: Performance focused - No compromise for lockout: The efficiency circuits (Pedal and Lock) sit behind the performance damping, meaning no sacrifice in bump performance for shredding downhill while keeping the ability to maintain pedalling stability for those leg burning climbs. - Rapid Recovery: More control with less energy. Bladder Charged - Extruded bladder design is insanely durable, resists damping change during extended downhills and has virtually zero pressure offset for small bump sensitivity. Trail Tuned - RCT3 features Open with adjustable low speed compression, Pedal and Lock. Solo Air: Solo Air is like a Buddhist monk. Its enlightened design lets you add air to your forks through a single Schrader valve, filling both the positive and negative air spring chambers simultaneously. So they're always in perfect equilibrium, like Yin and Yang. Giving you plush, predictable ride you can set up in seconds, with the lightest weight air spring on the market. Maxle Lite 15mm: Who obsesses over the weight of their wheel axles? It's ridiculous, right? It's just a rod of metal bolting the wheels to your bike. But then again, Maxle Lite is a nifty thru axle system that makes your bike both lighter and stiffer. And less weight makes it easier to get your bike to do what you want. Especially when you don't need to bring tools to remove it, front or rear. And that extra stiffness gives you the precision to hit your lines no matter how burly. So maybe that obsession isn't so ridiculous after all. Now available on the new PIKE in 15 x 100mm size. Power Bulge: When you need your forearms to be stronger for more control, you bulk them up in the gym. When you need more durability from your fork, bulk them up with SRAM's Power Bulge. Other companies just increase the stanchion size adding extra weight. Power Bulge simply reinforces the lower leg to allow for an oversized bushing, increasing stiffness and maximizing your ride. Plus, it's called Power Bulge. Rapid Recovery: Who doesn't want more available wheel travel for successive hits? The Rapid Recovery System allows the shock to recovery faster between consecutive bumps, letting the wheel track the ground with greater precision. This more active suspension system doesn't pack up and enables the bike to ride in a higher and softer part of the spring rate. Rapid Recovery gives the rider access to more available wheel travel, bump after bump, to achieve a smoother and more controlled ride.
Re: RS Pike RC Solo Air Vorsprung Luftkappe 29 140mm
[Re: rage]
#249276221/06/201807:28
