2017 Specialized Enduro Comp 29, størrelse M. Alu ramme. Som ny, uten merker / riper på rammen. Kjøpt september 2017 og har bare sett 200km rundt Bergen / Voss. 160 mm reise foran og bak med 29 hjulstørrelse = Shred Ready ! Kan også bruke ramme med 27+ / 3.0 (Fatty dekk) Original Roval 29er hjulsett rullet mindre enn 40km. Kan pakke og sendes i originalboks helt Norge. Ekstrautstyr - Ergon-grips, FUNN stem 90mm, Deore XT spd pedaler. '
24500 NOK
Full Specs:
CHAIN - SRAM PC-1110, 11-speed w/PowerLink
CRANKSET - RaceFace Aeffect, 28T Chainring
SHIFT LEVERS -SRAM NX, 11-speed, trigger
CASSETTE -SRAM XG-1150, 11-speed, 10-42t
REAR DERAILLEUR - SRAM GX, long cage, 11-speed
FORK - RockShox Yari 29 Solo Air, 160mm travel
FRONT HUB -Specialized disc, alloy, sealed cartridge bearings
REAR HUB -Specialized disc, alloy, sealed cartridge bearings
SPOKES -DT Swiss Industry, stainless, 3x, 2.0
RIMS -Roval Traverse, 29mm inner width, tubeless ready
FRONT TIRE - Schwalbe Nobby Nic (brukt)
REAR TIRE -Maxxis Aggressor (nesten ny)
SEATPOST - Specialized Command Post 125mm
HANDLEBARS - Specialized DH, 6061 780mm
FRONT BRAKE SRAM Guide R, Guide S4 4-piston caliper, 200mm rotor
REAR BRAKE SRAM Guide R, Guide S4 4-piston caliper, 180mm rotor
