Selger en pent brukt 2016 Norco Aurum A7.1 i størrelse medium for kr 18 000,-.
Sykkelen ble kjøpt ny fra butikk i 2017 og kun blitt brukt noen få ganger på Hafjell og Nesbyen. Nypris var 36 990,-.
Sykkelen befinner seg i Oslo og kan prøves etter avtale. Kan sendes mot at kjøper dekker fraktkostnader. Sykkelen selges uten pedaler.
Utstyrsliste:
Frame Aurum A 7.1 aluminum frame 200mm travel
Fork Rock shox Boxxer RC 27.5
Rear Shock Rock shox KAGE RC coil spring
Seat Post Norco 2014 alloy double bolt head
Seat Post ClampNorco design alloy nutted clamp (no cable guide)
Saddle WTB High Tail DH specific saddle cromo rail
Shifter Casing Jagwire LEX housing
Headset Cane Creek 40
Stem Race face Atlas Direct Mount 50 mm 35 bulge
Handlebar Race Face Atlas 20mmx800mm (35 mm bulge)
Grips Norco lock on
Brakes Sram Guide R 4 piston hydraulic disc
Chain Tensioner E-13 LG 1 +DMB guide with lower guard
Rims Sun Inferno 29 rim 27.5 black , with eyelet
Tires Maxxis Minion DHF frnt , DHR II rear 27.5x2.40
Tubes Schwalbe light weight MTB 27.5 tubes
Front Hub Formula alloy sealed bearing 20 mm
Rear Hub Sram MTH 746 w XD driver 142x12mm
Spokes/Nipples DT Champion black stainless steel
Shifter Rear Sram XO 1 DH 1x7
Rear Derailleur Sram XO 1 DH medium cage 7 speed RD
Cassette Sram XO1 DH 10-24T 7 spd casette CS HG795
Crankset E-13 LG 1 single crank
Bottom Bracket BB 83 threaded
Pedals N/A
Chain Sram PC X1 chain 108 link
Finn:
https://www.finn.no/bap/forsale/ad.html?finnkode=119415016&fks=119415016Er dessverre ikke så mye innom dette forumet, så hvis du lurer på noe send meg en mail: aksel86(snabel a)gmail.com
