Du bruker bluetooth med andre ord? Alt er mye enklere med ant+
Steps:
1. Using the Wahoo iOS app, pair your Kickr via Bluetooth under Sensors
2. Select the Kickr from the sensor menu
3. Enable "Control w/ ANT+ Power Meter" from the options.
4. Below this option, enter your Stages Power meter's ANT+ ID (from the silver sticker on the backside of the crank) under "ANT+ Power Device ID"
Once this is enabled, the Kickr trainer is able to pair to your power meter and read the power values. From these values, it will adjust the resistance in ERG mode.
Ser ut til å være ganske rett fram det.
