GARASJESALG - NYE PRISER - ALT SKAL UT
GARASJESALG - NYE PRISER - ALT SKAL UT #2444210 12/10/2017 10:43
Registrert: Apr 2014
Chris Braathen Offline OP
Hei igjen folkens.
Må rydde og alt skal ut. Det meste er nytt, noe er meget lite brukt. 50% - 70% av laveste normale nettpris dere finner, eller kom med bud.
RING ELLER SEND SMS TIL 906 00 000 - EVT. EPOST: CHRIS@POLYFACE.NO. SENDER HELE NORGE - HELST IKKE PM.
BILDER FINNER DERE HER: Dropbox Bike Parts Photos
LAUF GRIT 1.5"/1 1/8" TAPERED STEERER - 12MM QR - FLAT MOUNT (NY I ESKE)
ENVE ROAD 1.0 GAFFEL 1 1/8" STRAIGHT STEERER - OPEN DROPOUTS
9POINT8 FALL LINE 375MM X 125MM - 31.6MM - INLINE - INTERNAL (NY I ESKE)
RACEFACE NAXT CARBON SEATPOST 400MM X 31.6MM - 0MM OFFSET
ENVE SEATPOST 400MM X 30.9MM - 0MM OFFSET - FORRIGE VERSJON
CRANK BROTHERS COBALT 11 SEATPOST 350MM X 27.2MM - 25MM OFFSET
EASTON EC90SL CARBON 400MM X 27.2 - 0MM OFFSET
ENVE SES AERO HANDLEBAR CLIP-ON EXTENSIONS
EASTON EC90SL CARBON STEM 110MM +/- 0 GRADER - 31.8MM
CHRIS KING THREADFIT 30MM - BSA 73MM MTB BOTTOM BRACKET - CERAMIC - SILVER
CHRIS KING THREADFIT 24MM - BSA 73MM MTB BOTTOM BRACKET - CERAMIC - GOLD
ENDURO BSA30 XD15 CERAMIC ANGULAR CONTACT BOTTOM BRACKET
BB INFINITE BSA30 CERAMIC GLIDE BOTTOM BRACKET
RWC BSA30 WITH ENDURO XD15 CERAMIC BEARINGS - GREEN
*MAVIC SLR Ti CARBON ROAD PEDALS
3AX ERGO ROAD PEDALS FOR VONDE KNÆR - MÅ PRØVES!!!
2X Maxxis High Roller II - 27.5 X 2.4 - 3C Max Terra
2X Continental Der Baron 2.4 Project – 27.5 X 2.40 – ProTection Apex Skin
Continental Trailking ProTection Apex – 27.5 X 2.40 – ProTection Apex Skin
Schwalbe Hans Dampf – 27.5 X 2.35 – SnakeSkin, TL Easy – TrailStar
Schwalbe Magic Mary – 27.5 X 2.35 – SnakeSkin, TL Easy – TrailStar
KMC X11SL DLC BLACK CHAIN
ROTOR Q-RINGS MTB 2X SET - 44/33T - 104/64 BCD
E-THIRTEEN GUIDE RINGS GOLD - 32T AND 34T - 104 BCD (IKKE NARROW WIDE - FINT FOR GATE/SINGEL OSV.)
TUNE CANNONBAL LEFTY HUB GOLD - 32H
TUNE DC 15 SCHNELLSPANNER
TUNE SKYLINE CARBON BOTTLE CAGE
SIDI DRAGON SRS WHITE - 42.2
SMITH FOREFRONT AEROCORE GREY LARGE
MASSE FEITE FRESHE NYE GRIPS I DIVERSE FARGER OG MERKER - 100 KR PARET. ODI GRIPS KAN VELGE MELLOM GOLD, BLACK ELLER RED CLAMP RINGS.
CUSTOM TITAN-CARBON ROAD FRAME - MUST SEE!!!
SEVEN CYCLES ELIUM SG IMX CUSTOM GEO FOR 182-190CM HØYDE. TITAN AND CARBON - HIGH STRAIGHT STEERER, PERFECT FOR ADULTS THAT WANT TO RIDE LONG DAYS WITHOUT FEELING LIKE A U-SHAPE AFTER - FITS 182-190 PERFECT - BSA ROAD (68MM) BOTTOM BRACKET, OPEN DROPOUTS. SELGES SAMLET MED
CHRIS KING THREADFIT CERAMIC FOR 24MM ELLER 30MM FOR BSA 68
SEVEN TITAN SEATPOST CLAMP - RIM BRAKES
SEVEN CYCLES TITAN 400MM X 27.2 - 25MM OFFSET
SEVEN CYCLES TITAN STEM 120MM +/- 0 GRADER - 31.8MM
SEVEN CYCLES TITAN STRAIGHT BAR 720MM
Re: GARASJESALG - NYE PRISER - ALT SKAL UT [Re: Chris Braathen] #2453644 01/12/2017 20:54
Registrert: Dec 2003
Arne_And Offline
9point8 setepinne og Baron dekk mottatt i posten, takk for handelen!
Re: GARASJESALG - NYE PRISER - ALT SKAL UT [Re: Chris Braathen] #2454045 04/12/2017 16:15
Registrert: Sep 2015
Per-Christian Offline
pris for SIDI DRAGON SRS WHITE?
Re: GARASJESALG - NYE PRISER - ALT SKAL UT [Re: Chris Braathen] #2454954 11/12/2017 08:45
mob Offline
Takk for handelen.
Re: GARASJESALG - NYE PRISER - ALT SKAL UT [Re: Chris Braathen] #2456184 18/12/2017 20:50
Registrert: Apr 2013
Rotkiv Offline
Handler du hos Chris blir du mest sannsynlig veldig fornøyd... Slik som meg!
læringsresistent
