Sakset fra en pdf for Shimano kjede: In order to obtain good gear shifting performance, this
chain has a forward side and a reverse side, and the sides
are marked so that the chain will face the correct way
when installed. The proper design performance will be
obtained when the chain is installed so that it faces the
correct way. If it is installed so that it faces the opposite
way, the chain may come off and the bicycle may fall over
and serious injury may occur as a result.
Redigert av Tungtrådd; 28/05/2017 11:31.
