Norco Range C7.3 Medium New
Norco Range C7.3 Medium New #2408409 22/05/2017 12:46
Registrert: Jul 2016
Che3z Offline OP
Due to injury i will not be able to use it for some time. Had only one test ride on it so it is practically new, no scratches or anything. Can send.
21000NOK
172 - 179 cm M
Frameset
Frame Range 650B carbon 160 mm travel
Fork Rockshox Yari 170mm 15mm Solo Air
Rear Shock Fox Performance Float X 3 position LV EVOL
Components
Seat Post KS E-Ten integra 30.9mm seatpost w / remote
Seat Post Clamp Norco design alloy nutted clamp
Saddle WTB Volt Sport saddle
Shifter Casing N/A
Headset Cane Creek 10 series tapered (integrated)
Headset Spacer 1x10mm - Black / 1x5mm - Black
Top Cap Black alloy with Cane Creek logo
Stem Short reach stem 45mm or 55mm ext
Handlebar Norco 6061 alloy DB 25mm rise bar 780mm
Grips Norco lock on
Front Brake Shimano SLX BLM675 hydraulic disc brake
Rear Brake Shimano SLX BLM675 hydraulic disc brake
Chain Tensioner E-13 TRS+ upper guide w/ small bash guar
Brake Levers Shimano center lock SM-RT54 180 mm rotor
Wheels
Rims Alex MD 27 / 32.4mm outer tubeless ready
Tires Maxxis High Roller II 27.5 x 2.30 DC Folding
Tubes standard MTB tubes 27.5 x 2.3
Front Hub Sram 15x100mm front hub
Rear Hub Sram MTH 746 w XD driver
Spokes/Nipples Black stainless steel 2.0
Drivetrain
Shifter Front N/A
Shifter Rear Sram GX1 11 speed trigger shifter black
Front Derailleur N/A
Rear Derailleur Sram GX
Cassette Sram XG 1150 10-42T
Crankset Race Face Aeffect 1x11 30T
Bottom Bracket Race Face threaded for 73mm shell
Pedals Alloy Flat Pedal with steel pins
Chain Sram PC 1130 chain
Re: Norco Range C7.3 Medium New [Re: Che3z] #2408803 23/05/2017 17:33
Che3z Offline OP
Up 19000NOK
Re: Norco Range C7.3 Medium New [Re: Che3z] #2410513 30/05/2017 10:36
Che3z Offline OP
Up, Price can be discussed
Re: Norco Range C7.3 Medium New [Re: Che3z] #2411789 03/06/2017 15:29
Che3z Offline OP
up
Re: Norco Range C7.3 Medium New [Re: Che3z] #2420406 10/07/2017 18:39
Terjers Offline
Hei! Hvor i landet kan man kikke på sykkelen?
Stor sykkelkoffert leies ut. Plass til både terreng og landeveissykkel.
Hardplast med egne hjulposer. Låsbar. 400,-/helg 600,-/uke Dep. 500,-
