Helt ny Rock Shox selges da den ikke passer med fargen på sykkelen.
Travel: 120mm
Wheel size: 29
Spring: Solo Air
Damping: Motion Control
Adjustments: Air pressure via common Schrader valve, External Rebound, Lockout Threshold - Low Speed Compression to Lock with Remote Lever (available separately!)
Steerer: Tapered 1.5" to 1 1/8"
Steerer length: 265mm
Upper Tubes: 32mm
Disc brake mount: Post Mount
Maximum Rotor Size: 200mm
Drop out: 15mm Maxle Lite
Usikker på pris, så seriøse bud mottas.
