Sti HT 150mm / Commencal Meta HT AM Plus 27,5 Sml
Sti HT 150mm / Commencal Meta HT AM Plus 27,5 Sml #2334213 15/08/2016 15:41
GeirW Offline OP
Hei, selger junior sin sti hardtail som har vært litt i bruk i et år.
Passer for folk som er ca 145-165cm, velkommen for å prøve om den passer.
Finnkode 80754696, der finner du også bilder ICON_SMILE
Priside, ca 7000,-
Spesifikasjoner:
Frame: 2015 Meta HT AM 650B, alloy 6061 triple butted, Top tube hidden cable path, Tapered headtube
Forks: Marzocchi 350 R, 650b, tapered, travel 150mm, 15mm axle
Groupset:
Chainset: Alpha Forged 2x9, 22/36 T, 170mm On S, 175mm On M/L/Xl
Bottom Bracket: Isis Bb 68mm, Sealed Bearings
Brake/Shift Levers: SRAM X5 2x9 Spd
Front Derailleur: SRAM X5 High Direct Mount 2 Spd
Rear Derailleur: SRAM X5 9 Spd
Cassette: SRAM Pg950 11-34 T
Chain: Yaban 9 spd
Wheelset:
Rims: Alpha 650b 32h Double Wall, 24,5mm, Pin Joint
Hubs: Alpha 32h, Loose Ball Light Version, Light Quick Release Skewer
Spokes: Spoke Steel 1,8mm Black - Nipple Brass 12mm Black
Tyres: Maxxis High Roller LI 2.3, 60 Tpi, Kevlar Bead, Tubeless Ready - NEW
Components:
Front Brake:SRAM DB3 200mm/180mm, With Matchmaker - NEW
Handlebars: Alpha, Alloy 7075 double butted, 20mm rise, 750mm, Ø31,8mm
Grips: Commencal lock on, Ø30mm, soft compound, Neon Orange logo
Headset: Semi integrated, tapered ZS44/56, 1¿¿1/8 race crown, ball retainer
Stem: Alpha, Alloy 2014 Forged, 50mm, O rise, Ø31,8mm - NEW
Saddle: Commencal Meta Am By Velo, Crmo Rails
Seatpost: Kindshock Eten, 100mm Travel, Ø31,6mm, 385mm, Kgp Lever
Re: Sti HT 150mm / Commencal Meta HT AM Plus 27,5 Sml [Re: GeirW] #2335837 19/08/2016 17:48
GeirW Offline OP
Tar en fredagsbump med bilder.
Sykkelen er mere for moro på sti enn kalas cup.
Prisen kan vi diskutere.
Redigert av GeirW; 19/08/2016 17:50.
Re: Sti HT 150mm / Commencal Meta HT AM Plus 27,5 Sml [Re: GeirW] #2336184 21/08/2016 08:37
GeirW Offline OP
Setter prisen til 5000,- for de som vil ha en leken stihardtail i skogen.
Re: Sti HT 150mm / Commencal Meta HT AM Plus 27,5 Sml [Re: GeirW] #2337322 23/08/2016 19:02
GeirW Offline OP
Solgt.
Re: Sti HT 150mm / Commencal Meta HT AM Plus 27,5 Sml [Re: GeirW] #2337511 24/08/2016 07:45
erikskon Offline
Der ser det ut til at en eller annen unge/ungdom får mye billig moro! Noen gjorde vel et kupp her.
