Bruktpris Specialized Stumpjumper Expert Carbon
Bruktpris Specialized Stumpjumper Expert Carbon #2318625 22/06/2016 19:07
Registrert: Jul 2015
valo79 Offline OP
Hei!
Har en 2008 modell Specialized Stumpjumper Expert fullkarbon hardtail som jeg vurderer å selge da den ikke blir brukt. Den er minimalt brukt, og har nettopp hatt service (ny kasett, drev og kjede + bremseskiver og slitedeler).
Kjøpt hos milslukern til 23000 kr (veiledende 30000). Men det betyr jo ikke så mye.
Hva kan man forvente å få for noe slikt ? 26 tommere er vel ikke det hotteste for tiden. Takk for innspill !
Specs:
Frame & Fork
Frame Construction Bonded/monocoque
Frame Tubing Material FACT 9m carbon
Fork Brand & Model Fox F90RL, 90mm travel
Fork Material Single
Rear Shock Not applicable
Components
Component Group Mountain Mix
Brakeset Avid Ultimate 7, hydraulic disc, 160mm rotor brakes, Avid Ultimate 7, hydraulic disc levers
Shift Levers SRAM X-9 Trigger
Front Derailleur Shimano LX, dual-pull/clamp-on 34.9mm
Rear Derailleur SRAM X-0
Crankset Shimano M-762 XT, 22/32/44 teeth
Pedals Crank Brothers Smarty
Bottom Bracket Shimano XT
BB Shell Width Unspecified
Rear Cogs 9-speed, 11 - 34 teeth
Chain SRAM PC-971 with Power Link, 1/2 x 3/32"
Seatpost 2014 butted alloy, single bolt setback, 30.9mm diameter
Saddle Specialized XC MTB, hollow Cr-Mo rails
Handlebar Specialized XC flat 31.8mm bar, 2014 butted alloy, 600mm wide
Handlebar Extensions Not included
Handlebar Stem Specialized, 31.8mm clamp, 3D forged w/CNC finish
Headset 1 1/8" threadless Campy spec integrated sealed cartridge bearing
Wheels
Hubs Front: Specialized Hi Lo disc, Rear: DT Swiss
Rims DT Swiss X420, 28-hole/32-hole
Tires 26 x 2.00" Specialized Fast Track Control LK
Spoke Brand DT Swiss stainless steel, 1.8/1.6 double-butted
Spoke Nipples Unspecified
Re: Bruktpris Specialized Stumpjumper Expert Carbon [Re: valo79] #2318643 22/06/2016 20:09
Registrert: Sep 2014
KlabbOgBabb Offline
Mulig jeg er kjip, men hadde ikke betalt over 1500.- for den.
Treig oppover, feig nedover.
Re: Bruktpris Specialized Stumpjumper Expert Carbon [Re: valo79] #2318651 22/06/2016 20:26
valo79 Offline OP
ok da hadde jeg behold den ICON_SMILE
Re: Bruktpris Specialized Stumpjumper Expert Carbon [Re: valo79] #2318652 22/06/2016 20:36
olechr Offline
8 år gammel hardtail er dessverre ikke vært rare greiene. Tipper 1000-3000 kroner.
Ambassadør for Scott.
Re: Bruktpris Specialized Stumpjumper Expert Carbon [Re: valo79] #2318658 22/06/2016 20:46
vehe Offline
Eneste måten du kan nærme deg 3000,- på er om vekta er lav, da kan du bruke det som argument om en eventuell kjøper bare har tunge alternativer i form av hyllevare fra nærmeste kjede.
Re: Bruktpris Specialized Stumpjumper Expert Carbon [Re: valo79] #2318659 22/06/2016 20:47
Asso$ Offline
http://www.finn.no/75046912
Ikke hør på disse utstyrsfreakene. Se hva jeg fikk 1500 kroner for i våres. 2001 mod. Gir fungerte bra men driverk, hjul osv var slitt med stor T
Nedgradert til fjærdemper. Teipet over lokket på ene siden ettersom det ble ødelagt. Noe jeg informerte kjøper om. Men demperen fungerte likevel fint
Redigert av Asso$; 22/06/2016 20:50.
Re: Bruktpris Specialized Stumpjumper Expert Carbon [Re: Asso$] #2318726 23/06/2016 06:18
KlabbOgBabb Offline
Du skrev ikke noe om slitte deler i annonsen... Sånt syns jeg ikke noe om.
Re: Bruktpris Specialized Stumpjumper Expert Carbon [Re: Asso$] #2318733 23/06/2016 06:36
sveinaa Offline
Hadde max betalt en 500 lapp for den sykkelen din. Så selv om du vant i LOTTO og snublet over en blind eller uerfaren kjøper så kan ikke alle andre belage seg på det samme.
Redigert av sveinaa; 23/06/2016 06:38.
Re: Bruktpris Specialized Stumpjumper Expert Carbon [Re: valo79] #2318794 23/06/2016 08:12
Asso$ Offline
Hei. Jeg har selv prøvd å finne en sykkel i den prisklassen som en sykkel jeg kunne sette fra meg i Oslo. Og prisnivået er ganske høyt på de aller billigste syklene. Nå var det bare kjede og kassett/klinger som var slitt og det må man forvente av en 01 modell til den prisen. Noe jeg informerte kjøper om. Mener ikke man kan forvente at sånt skal være nytt heller på en sånn sykkel. Men mulig det burde stått i annonsen ja. Men kjøper fikk vite det.
For 500 kroner, særlig i Oslo får du en sykkel som faller fra hverandre. Og tro meg jeg har vært å prøvd dem. Har lett på finn etter sykler for studiekamerater da jeg gikk på skole der inne.
Så dere kan bare fortsette med hersketeknikkene deres. De fleste syklene til 1000-1500 kroner på finn er ikke behandlet like bra som av de som sykler mer eller mindre aktivt.
Jeg personlig ville heller hatt en gammel sykkel med XT gruppe enn en nyere acerca/altus sykkel til pendling. De som selger en tre år gammel altus har sjelden tatt så godt vare på sykkelen sin heller. Tror jeg.
Flaks å møtt på en uvitende kjøper? Jeg betalte selv 1300 kroner for en eldgammel stuntjumper i 2014. Solgte den igjen etter noen måneder da den var for liten for meg. Solgte den for samme pris og kjøper var veldig fornøyd. Ramma var av stål men sykkelen var ellers i god stand. Nok en gang, noe jeg informerte kjøper om.
Solgte også en Hard Rocx equlibrium 2004 modell i 2014. Vi var en gjeng fra Larvik som syklet Vasan 2013 og HR'en kom inn på best tid i den troppen. Fungerte greit bortsett fra at bakgiret måtte byttes. Igjen. Noe jeg informerte kjøper om! V brems. Xtr gruppe.
Det kom en danske på døra som skulle bruke den til å sykle til jobb i Larvik fra Sandefjord. Han var helt ellevill. Han hadde hatt en annen Hard Rocx som hadde tatt kvelden. Fikk mye skryt for at det var Xtr gruppe, at den var fin i lakken og at det var satt på et falc sykkelregister merke.
I ettertid har jeg møtt han syklende fra til Sandefjord fra Larvik så sykkelen lever i beste velgående etter at han fikk byttet bakgir. Faktisk har jeg angret på at jeg ikke beholdt den som vintersykkel. Fikk 3000 kroner for den.
Dere som mener man får en velfungerende sykkel på finn i Oslo til pendling i størrelse large/xl for 500 kroner kan ta dere en bolle. Prisnivået er ikke slik. Greit at ikke dere vil betale mer, det er greit men slik er altså ikke bruktmarkedet. Ihvertfall var det ikke slik sist jeg sjekket (2014)
Mange som bytter sykler annenhvert år her inne vil jeg tro. Og da blir svarene derretter.
Redigert av Asso$; 23/06/2016 08:29.
Re: Bruktpris Specialized Stumpjumper Expert Carbon [Re: valo79] #2318798 23/06/2016 08:25
Registrert: Jan 2012
MAN Offline
Jeg tror størrelse spiller en viktig rolle her.
Er det small/medium fins det ufattelig mye på finn allerede. Men for de som er høyere, er det lengre mellom kuppene på finn.
Er den L eller XL tror jeg du får mer for den.
Jeg kunne godt kjøpt denne for 1500-2000 om den var i rett størrelse ICON_SMILE
Yeti SB130
Instagram
Re: Bruktpris Specialized Stumpjumper Expert Carbon [Re: valo79] #2318805 23/06/2016 08:35
Registrert: Jul 2017
anonym22 Offline
Anonym22
Anonym22
Litt useriøst å påstå at denne sykkelen knapt har verdi. Hva slags bruk- og kastmentalitet er det at sykler knapt tåler et par sesongers bruk? Hver gang jeg ser på sykler som er ferdige på service i butikkene, er det flere virkelig verdiløse sykler som har fått skiftet slitedeler og blitt "servet" for et par tusen. Det er litt trist. Men dette er jo en tidligere "toppsykkel", som er lite brukt, og nettopp har fått byttet slitedeler for 500-1000 kroner.
Hvis den er i Large, i god stand ellers og uten opplagt behov for nye lager her og der, vil jeg si at 3000 er en grei pris på Finn. Det kan da faktisk være et godt kjøp for en allround brukssykkel, hvis den viser seg å ikke ha noen problemer som dukker opp i løpet av kort tid.
Re: Bruktpris Specialized Stumpjumper Expert Carbon [Re: valo79] #2318806 23/06/2016 08:36
Asso$ Offline
Det er mulig. Men jeg opplever at det tar mye lenger tid å få solgt 21" terrengsykkel og 58 cm racere jeg har hatt enn fks 19" terrengsykkel jeg har brukt til å sykle med i Oslo sentrum. Flere annonser men også flere kjøpere ICON_SMILE
Edit: Mente å quote MAN over her ICON_SMILE
Redigert av Asso$; 23/06/2016 08:41.
Re: Bruktpris Specialized Stumpjumper Expert Carbon [Re: anonym22] #2318813 23/06/2016 08:52
sveinaa Offline
Sitat: anonymous22
Hadde du bladd opp 3 lapper for den HR sykkelen?
Re: Bruktpris Specialized Stumpjumper Expert Carbon [Re: valo79] #2318822 23/06/2016 09:03
Asso$ Offline
Hvis du tenker på den jeg solgte for 1500 så er jo det en sykkel som gikk for 1500, ikke 3000. Den gikk etter én dag.
Re: Bruktpris Specialized Stumpjumper Expert Carbon [Re: sveinaa] #2318824 23/06/2016 09:08
anonym22 Offline
Anonym22
Anonym22
Sitat: sveinaa
Hvis jeg hadde null brukssykler/jobbpendlere, og den er i super stand, så ville den vært bedre enn det man får nytt til lav pris. Men jeg ville like gjerne brukt mer penger ICON_WINK
Ville du solgt den for 500?
Edit: Jeg mente her TS sin sykkel.
Redigert av anonym22; 23/06/2016 09:34.
Re: Bruktpris Specialized Stumpjumper Expert Carbon [Re: valo79] #2318833 23/06/2016 09:29
DBrodshaug Offline
Det koster jo uansett ikke noe å legge den ut.
Den er jo meget potensiell som pendler/vintersykkel. Dette er også et prissegment det ikke er mye å velge i på finn. Så etter hardtail til vinterpendling i fjor, og det typiske er at folk som kjøper sykkel til 10-12 tusen veiledende tror de kan få 8-10 tusen igjen for de.. Det hjelper ikke at syklene har stått tilnærmet ubrukt i 1-2 år når man kan gå i butikk og få samme pris.
Re: Bruktpris Specialized Stumpjumper Expert Carbon [Re: anonym22] #2318834 23/06/2016 09:32
sveinaa Offline
Sitat: anonymous22
Sitat: sveinaa
Les hvordan han beskriver tilstanden. Alle som skrur litt selv vet at det fort baller på seg når man begynner å skifte ut slitedeler.
Re: Bruktpris Specialized Stumpjumper Expert Carbon [Re: DBrodshaug] #2318835 23/06/2016 09:32
anonym22 Offline
Anonym22
Anonym22
Sitat: DanielBrodshaug
(...)det typiske er at folk som kjøper sykkel til 10-12 tusen veiledende tror de kan få 8-10 tusen igjen for de.. Det hjelper ikke at syklene har stått tilnærmet ubrukt i 1-2 år når man kan gå i butikk og få samme pris.
+1
Re: Bruktpris Specialized Stumpjumper Expert Carbon [Re: anonym22] #2318836 23/06/2016 09:34
sveinaa Offline
Sitat: anonymous22
Sitat: sveinaa
Om den tok opp plass, ja!
Re: Bruktpris Specialized Stumpjumper Expert Carbon [Re: sveinaa] #2318837 23/06/2016 09:35
anonym22 Offline
Anonym22
Anonym22
Sitat: sveinaa
Sitat: anonymous22
Sitat: sveinaa
Jeg tenke på TS sin sykkel, ikke Asso$ sin. My bad. Nei, sykkel med skrikende behov for service hadde jeg ikke betalt for.
Re: Bruktpris Specialized Stumpjumper Expert Carbon [Re: sveinaa] #2318838 23/06/2016 09:36
anonym22 Offline
Anonym22
Anonym22
Sitat: sveinaa
Sitat: anonymous22
Sitat: sveinaa
Jeg hadde gitt bort den HRen.
Re: Bruktpris Specialized Stumpjumper Expert Carbon [Re: valo79] #2318859 23/06/2016 10:51
Asso$ Offline
Jeg tror dere har misforstått.
Den sykkelen på finn hadde slitt kjede og kassett. Ellers fungerte alt utmerket.
Jeg fikk 3k for en Hard Rocx som bakgiret måtte byttes på men det var en annen sykkel enn den som jeg linket til i annonsen.
Jeg har altså IKKE solgt denne sykkelen for 3000 kroner
Re: Bruktpris Specialized Stumpjumper Expert Carbon [Re: valo79] #2320253 27/06/2016 20:49
steffs Offline
Berre at der er ein Specialized stumpy gjer den verdt minst 3000 kr. Hadde eg berre hatt plass til n+1 sykkel til i boda så kunne den her fått fast oppkobling på sykkelvogna t kidsa. Stumpjumper e nostalgi, har sjølv hatt 2007 og 2008 modell av denne i alu. Har faktisk prøvd å kjøpe igjen 2008 mod av han eg solgte den til. Ein god regel som eg pleie bruke er " kor mykje ville eg sjølv betalt for den" .
gnetepeisane lenger opp i tråden prøva berre å gjere eit godt gammaldags røvarkjøp.
Steffen
"Eit smart hus er ikkje dumt i morgon"
Steffen Herstad
Re: Bruktpris Specialized Stumpjumper Expert Carbon [Re: valo79] #2321992 02/07/2016 20:30
valo79 Offline OP
Hei !
Jeg fikk 6000 kr for sykkelen. Fikk også noen bud på både 7500 og 8000 kr, men dette var ikke lokalt så gadd ikke stresse med å frakte.
Så blir litt dumt å lese mange av kommentarene her. Er ikke alle som trenger det nyeste. Og jeg vil påstå at en 2008 modell stumpjumper er bedre enn en ny white til 8000 kr.
Redigert av valo79; 02/07/2016 20:31.
Re: Bruktpris Specialized Stumpjumper Expert Carbon [Re: valo79] #2322072 03/07/2016 09:50
KlabbOgBabb Offline
Sitat: valo79
Hei !
Står fortsatt ved min pris. Selv om du syns det er dumt...
Du spurte om vår mening og du fikk den. At jeg personlig ikke ville betalt så mye for en 8år gammel sykkel har egentlig ingenting å si sålenge du og kjloer er fornøyde.
Re: Bruktpris Specialized Stumpjumper Expert Carbon [Re: valo79] #2322075 03/07/2016 10:17
Denne tråden illustrerer i hvert fall godt at de fleste betraktninger omkring hva en bruktsykkel er verdt ikke er mye verdt ICON_LAUGH
Re: Bruktpris Specialized Stumpjumper Expert Carbon [Re: valo79] #2322225 04/07/2016 01:05
Asso$ Offline
Heisann sykkelsnobber ICON_WINK
Han spurte ikke om deres mening. Han spurte hvor mye han kunne regne med å få for den. Helt enig at det er bedre med en gammel Xt sykkel i ok stand enn en ny med alivio gruppe.
At enkelte her har skrevet at jeg vant i lotto som fikk 1500 kr for hard rocx er regelrett skivebom.
Men hva gjør man ikke for å reddferdiggjøre egne sykkelkjøp årlig.
Dette bare viser at folk er villig til å betale for gamle sykler. Selv om de aller fleste mennesker skjønner at gamle ting ikke lenger er nye.
Jeg ble jo nærmest anklaget for svindel her inn fordi jeg skrev "Kvalitetsdeler fra shimano" i artikkelen. Hva er galt med det? Xt er kvalitet.
Skulle jeg pressisere at drivverket på en 15 år gammel sykkel var gammelt? Skulle jeg brukt 1000 kroner på å bytte dette på en 1500 kroners sykkel, og hadde dette vært lønnsomt? Det var en oppegående mann som kjøpte sykkelen. Som helt sikkert skjønner at det aldri er noen garanti for hvor lenge gamle, 1500 kroners sykler holder. Han skulle ha det til sønnen som var i en voksefase og får sikkert 1000 kroner for sykkelen når han selger den igjen om noen år.
Re: Bruktpris Specialized Stumpjumper Expert Carbon [Re: Asso$] #2323522 07/07/2016 21:01
valo79 Offline OP
Takk for dette. Assos.... Ja jeg spurte hva jeg kan forvente å få. Ikke hva medlemmene her ville betalt.
