Scott Scale 700 RC 27,5 ", Small, 2014 selges
Scott Scale 700 RC 27,5 ", Small, 2014 selges #2080725 17/04/2016 13:05
Registrert: Apr 2016
I
ilra Offline OP
I
Scott Scale RC 700 størrelse small selges kr. 25000.
Ordinær pris i 2014 var 52.000.
Min høyde er 160 cm og ramme str. er ca 16 ".
Se bilder på Finn.no : http://m.finn.no/bap/forsale/ad.html?finnkode=73435421
1 x 11 Sram Gripshift XX1.
Topp rittsykkel kjøpt ny hos Sportssenteret Halden 270714.
Service juli 2015 og ikke mye brukt etter dette.
Fra Scott sine sider:
Frame Material Carbon
Rear Travel N/A
Rear Shock N/A
Fork
RockShox SID 29 RL3 Air, DNA3 Custom Damper with 3 Modes, 15mm QR Axle, Tapered Steerer, Rebound Adjust, with Scott RideLoc Remote Technology
Fork Travel
100mm
Head Tube Diameter
Tapered
Headset
Ritchey Pro Tapered 1.5" to 1-1/8", Semi Integrated OD 50/61mm / ID 44/55mm
Handlebar
Ritchey Carbon WCS 2X, T Shape Flat, 9 , 700mm
Stem
Ritchey WCS C-260, Oversize 31.8mm, 1-1/8", 6 Angle, Length on Size: S-70mm, M-80mm, L-90mm, XL-100mm
Grips
Syncros Silicone
Brakes
Shimano XTR M987 Disc, 180mm Front and 160mm Rear SM-RT67 CL Rotors
Brake Levers
Shimano XTR XC M987 Disc
Shifters
SRAM X01 Trigger, Right Only
Front Derailleur
N/A
Rear Derailleur
SRAM XX1, 11-Speed
ISCG Tabs
N/A
Chainguide
N/A
Cranks
SRAM XX1 GXP PF Carbon Arm, QF 156
Chainrings
34 Tooth
Bottom Bracket
SRAM GXP PF Integrated, Shell 41x89.5mm
Pedals
N/A
Chain
SRAM PC XX1
Cassette
SRAM X01, XG1195, 10-42 Tooth
Rims
Syncros XR RC, 28 Hole, Tubeless Ready, 27.5"
Hubs
Syncros XR RC CL Made by DT Swiss Front // Syncros XR RC CL RWS XD Body Made by DT Swiss Rear
Spokes
DT Swiss Aero Comp
Tires
Schwalbe Thunder Burt
Schwalbe Rocket Ron EVO, 27.5"x 2.1", 127EPI Kevlar Bead,
Saddle
Ritchey WCS Streem EVO
Seatpost
Ritchey WCS, Carbon Link Flex Logic
Seat Post Diameter
31.6mm
Seatpost Clamp
Standard
Rear Dropout / Hub Dimensions
Interchangeable IDS SL for 142mm x 12mm
Max. Tire Size
Bottle Cage Mounts
Yes
Colors
Black/White/Yellow
Warranty
5 Years for Frames and Swingarms
Weight
18 lb 15.4 oz (8.6 kg)
Re: Scott Scale 700 RC 27,5 ", Small, 2014 selges [Re: ilra] #2323083 06/07/2016 13:29
Registrert: Jul 2016
Pøstmoen Offline
Solgt?
