Selger min Scott Spark RC 29" str. L. Svært lite brukt da jeg har roet ned satsingen på sykkel. Ble kun brukt på noen få treninger og NC Fiskum.
Sykkelen kan sees i Oslo.
Send en PM om du interessert.
Selges for 30.999 ,-
Bilder kommer.
Spec:
Frame Material IMP, HMX, Carbon / Carbon Swingarm with 160PM
Rear Travel 100mm / 70mm / Climb
Rear Shock FOX Nude, Scott Custom with Travel/Geometry Adjust, CTCD 3 Modes: Climb/Traction Control/Descend, Rebound Adjust
Fork FOX 32 Float Factory CTD Air, CTD Damper with 3 Modes, 15mm QR Axle, Tapered Steerer, Rebound Adjust
Fork Travel 100mm
Head Tube Diameter Tapered
Headset Ritchey Pro Tapered 1.5" - 1-1/8", Semi Integrated OD 50/61mm / ID 44/55mm
Handlebar Ritchey Carbon WCS 2X, T Shape Flat, 9 , 700mm
Stem Ritchey WCS C-260, Oversize 31.8mm, 1-1/8", - 6 Angle
Grips Syncros Pro Lock-On
Brakes Shimano XTR M9000 Disc, 180mm Front and 160mm Rear SM-RT81 CL Icetech Rotors
Brake Levers Shimano XTR XC M9000 Disc
Shifters SRAM X01 Trigger, Right Only, Multi Adjust, with Carbon Cap
Front Derailleur N/A
Rear Derailleur SRAM XX1, 11-Speed
ISCG Tabs N/A
Chainguide N/A
Cranks SRAM XX1 GXP PF, Carbon Crankarm, QF 168
Chainrings 32 Tooth
Bottom Bracket SRAM GXP PF Integated, Shell 41x89.5mm
Pedals N/A
Chain SRAM PC XX1
Cassette SRAM X01, XG1195, 10-42 Tooth
Rims Syncros XR RC, 28 Hole, Tubeless Ready
Hubs Syncros XR RC CL Made by DT Swiss Front
Syncros XR RC CL, RWS Axle, Rachet System, XD, Made by DT Swiss Rear
Tires Schwalbe Rocket Ron EVO 29" x 2.25", 127EPI Kevlar Bead, Tubeless Easy, PaceStar Compound
Saddle Ritchey WCS Streem EVO
Seatpost Ritchey WCS Carbon Link
Seat Post Diameter 31.6mm
