Selger min Specialized Stumpjumper Comp Carbon 29, str. L / 19". Passer for rytter fra 178 cm til 188 cm.
Kjøpt av meg på Hank Sport i 2012, kostet da 20 000,-
Anslår at jeg brukt den på ca 30 økter.
Sendes ikke, må hentes på Tyholt.
Pris? Uvisst. Veldig lite brukt, men 3 sesonger gammel. Kom med bud.
Det er et par avvik fra bildet, bl.a. annet sete, holker og dekk (Crossmark).
Specs følger:
Frame:FACT 8m carbon, 29" geometry, FACT IS construction, tapered HT, carbon PF30 BB, hollow carbon dropouts, replaceable alloy derailleur hanger
Fork:RockShox Reba RL 29, tapered alloy steerer, LO and reb adj., standard drop-outs, 90mm
Front Derailleur:SRAM X7, 10-speed, S3 direct mount for DMD, high clamp
Rear Derailleur:SRAM X9, 10-speed, mid cage
Shifters:SRAM X7, 10-speed, aluminium trigger, with Matchmaker clamps
Chainset:Custom SRAM S-1250, 7050 alloy arms, 10-speed XC double, PF30 spindle, 175mm
Bottom Bracket:SRAM PF30, OS press-in bearing, sealed cartridge
Cassette:SRAM PG-1030, 10-speed, 11-36t
Chain:KMC X-10, 10-speed, with reusable Missing Link, nickel plates
Front Brake:Custom Avid Elixir 7 SL, hydraulic disc, alloy backed semi-metallic pad, 160mm HS-1 rotor
Rear Brake:Custom Avid Elixir 7 SL, hydraulic disc, alloy backed semi-metallic pad, 160mm HS-1 rotor
Brake Levers:Custom Avid Elixir R SL hydraulic, tool-less reach adj., with Matchmaker clamps
Handlebars:Specialized XC flat, 2014 butted alloy, 680mm wide, 8 degrees back sweep, 31.8mm
Stem:Specialized XC, 3D forged alloy, 4-bolt, 31.8mm clamp, adjustable rise, S: 75mm, M: 90mm, L: 105mm, XL: 105mm
Headset:1-1/8 and 1-1/2" Threadless, Campy style upper with 1-1/2" lower bearing for tapered integrated HT, cartridge bearings
Rims:Roval 29, 26mm with eyelets, 32h
Front Hub:Specialized Hi Lo disc, laser-etched logo, OS 28 end caps, sealed cartridge bearing, RWS, 32h
Rear Hub:Specialized Hi Lo disc, laser-etched logo, double-sealed cartridge bearing, QR, 32h
Spokes:DT Swiss Industry 2.0, (14g) stainless
Saddle:Fizik Arione XM
Seatpost:2014 butted alloy, single bolt setback, 27.2mm, 350mm 15.5/17.5"
