Sykkelen er ny, bare tatt opp av esken og montert. Bilder skaffes ved henvendelser. Send pm
Sykkelen selges for 15000,-
Fork FOX 32 Float Factory CTD Air, CTD Damper with 3 Modes,
15mm QR Axle,
Tapered Steerer,
Rebound Adjust, with Scott RideLoc Remote Technology
Fork Travel
100mmHead Tube Diameter
TaperedHeadset Ritchey Pro Tapered 1.5" to 1-1/8", Semi Integrated OD 50/61mm / ID 44/55mm
Handlebar Syncros FL1.5 T-Bar, Alloy 7050 D.B., T Shape Flat, 9°, 700mm
Stem Syncros, XR1.5 (-10°), 7050 Alloy, 31.8mm, 1-1/8", Length on Size: S-70mm, M-80mm, L-90mm, XL-100mm
Grips Syncros Pro Lock-On
Brakes Shimano XT BR-M785 Disc, 180mm Front and 160mm Rear SM-RT64 CL RotorsBrake Levers Shimano XT BL-M785 Disc
Shifters Shimano XT SL-M780-I, Rapidfire Plus, 2 Way Release, Ispec Clamp
Front Derailleur Shimano XT FD-M786, 34.9mm
Rear Derailleur Shimano XT RD-M786 SGS Shadow Plus Type, 20-SpeedISCG Tabs N/AChainguide N/A
Cranks Shimano XT FC-M785, Hollowtech 2Chainrings 38A/ 24A Tooth
Bottom Bracket Shimano SM-BB71-41A, Shell 41x89.5mm
Pedals N/A
Chain Shimano CN-HG74
Cassette Shimano CS-HG81-10, 11-36 Tooth
Rims Syncros XR2.0, 28 Hole, Tubeless Ready, 29"
Hubs Syncros XR2.0 CL Made by DT Swiss Front // Syncros XR2.0 CL RWS Made by DT Swiss Rear
Spokes DT Swiss Aero Comp
Tires Schwalbe Rocket Ron EVO, 29"x 2.1", 127EPI Kevlar Bead, Tubeless Ready, PaceStar Compound
Saddle Syncros XR1.5, Titanium Rails
Seatpost Syncros FL1.5Seat Post Diameter 34.9mm
Seatpost Clamp StandardRear Dropout / Hub Dimensions Interchangeable IDS SL for 142mm x 12mm
