2014 Trek remedy 7 650B/27.5 XL
2014 Trek remedy 7 650B/27.5 XL #1977359 27/06/2015 18:56
Registrert: Jun 2014
kaputt6 Offline OP
Selger min et år gamle Trek Remedy 7 650b 27.5
Størrelse er XL 21.5, men de er mindre i størrelsen enn vanlig, så den passer til meg som er 187cm.
Har kun byttet styrestem til litt kortere. Orginal medfølger.
Nuke electron flat pedaler.
Ny pris: 24000 i fjor sommer.
Selges kr: 14000
Som ny.
Noen kosmetiske "striper", men helt fin stand.
Specifications:
Model Year2014
Riding TypeTrail
Sizes and Geometry
15.5 (Low/High), 17.5 (Low/High), 18.5 (Low/High), 19.5 (Low/High), 21.5 (Low/High) View Geometry
Frame MaterialAlpha Platinum Aluminum
Rear Travel140mm
Rear ShockFOX Evolution Series Float with DRCV, CTD Damper, Rebound, 7.75x2.25"
ForkRockShox Revelation RL with Solo Air, Rebound, Lockout, E2 Tapered Steerer, 15mm Maxle Lite
Fork Travel140mm
Head Tube DiameterE2 Tapered
HeadsetFSA IS-2, E2, Sealed Cartridge Bearing
HandlebarBontrager Low Riser, 31.8mm, 15mm Rise
StemBontrager Rhythm Comp, 31.8mm, 0
GripsBontrager Rhythm, Dual Lock-On
BrakesShimano M615 Hydraulic Disc
Brake LeversShimano M615 Hydraulic Disc
ShiftersShimano Deore, 10-Speed
Front DerailleurShimano Deore, High Direct Mount
Rear DerailleurShimano SLX Shadow Plus
ISCG TabsISCG 05
ChainguideN/A
CranksShimano M622
Chainrings40/30/22 Tooth
Bottom BracketShimano Press Fit
PedalsN/A
Chain
CassetteShimano HG62, 11-36 Tooth, 10-Speed
RimsBontrager Duster 28-Hole Tubeless Ready
HubsBontrager Alloy Front, Bontrager Sealed Cartridge Bearing Rear
Spokes
TiresBontrager XR3 Expert, Aramid Bead, 27.5x2.35"
SaddleBontrager Evoke 2, Chromoly Rails
SeatpostBontrager SSR, 12mm Offset
Seat Post Diameter31.6mm
Seatpost ClampQuick Release
Rear Dropout / Hub Dimensions
Max. Tire Size
Bottle Cage MountsYes
ColorsMatte Dnister Black/Team Green
WarrantyLifetime Frame, 5 Year Swing Arms
Weight
N/A
Miscellaneous
Tilstand: Brukt
Re: 2014 Trek remedy 7 650B/27.5 XL [Re: kaputt6] #1982623 11/07/2015 21:08
Registrert: Jul 2015
cheesemonger Offline
Fortsatt til salgs?
Re: 2014 Trek remedy 7 650B/27.5 XL [Re: kaputt6] #1992532 07/08/2015 19:20
Registrert: Aug 2015
DeltaKilo Offline
Lurer på det samme ICON_SMILE
