FS: Specialized Myka FSR Elite 2011
FS: Specialized Myka FSR Elite 2011 #1957183 10/05/2015 16:07
gran Offline OP
Har ein Specialized Myka FSR Elite 2011 som er helt ny og aldrig brukt, denne ble innkjøpt till fruen i håp om att hun skulle begynne med sti men nå har jeg måtte inse fakta att det aldrig kommer till å skje.
Dette er ein ypperlig FS Sykkel for dama i rett farge og allt,
utstyr er:
FRAMEM4 hydroformed tubing, women's TT, DT & XC Trail geometry, curved TT S&M, sealed cartridge bearings, bolt on cable guides, replaceable derailleur hanger, 100mm travel
REAR SHOCKRockShox Ario, air spring, rebound adj. and LO, 6.5x1.5"
FORKRockShox Recon Gold TK, Turn Key damper, Solo Air, alloy steerer, rebound adj. w/ LO, disc only, 100mm travel
HEADSET1 1/8" upper and lower campy style cartridge bearings for integrated alloy HT
STEMSpecialized XC, 3D forged alloy, 4-bolt, 31.8mm clamp, adjustable rise
HANDLEBARSSpecialized XC low-rise, 6061 butted alloy, S/M: 640mm wide, L: 660mm wide, 8 degree backsweep, 6 degree up, 31.8mm
GRIPSSpecialized XC lock-on
FRONT BRAKECustom Avid Elixir 3 R SL, hydraulic disc, tool-less reach adjust, alloy backed organic pads, G3 Clean Sweep, 160mm
REAR BRAKECustom Avid Elixir 3 R SL, hydraulic disc, tool-less reach adjust, alloy backed organic pads, G3 Clean Sweep, 140mm
BRAKE LEVERSCustom Avid Elixir 3 SL hydraulic, tool-less reach adj.
FRONT DERAILLEURShimano FD-M660 SLX, E-type for DMD, top swing, bottom pull
REAR DERAILLEURShimano RD-M772 Deore XT Shadow, long cage
SHIFT LEVERSShimano SL-M430 Alivio, 9-speed, trigger
CASSETTE Shimano HG30, 9-speed, 11-34t
CHAINKMC X9, 9-speed, w/ reuseable Missing Link
CRANKSETShimano FC-M521, Hollowtech, Octalink spline, replacable rings w/ alloy outer, S/M: 170mm, L: 175mm
CHAINRINGS44A x 32Sx 22S, 4-bolt, 104/64mm
BOTTOM BRACKET Shimano BB-ES25, Octalink spline, cartridge bearing
RIMSCustom DT Swiss 445D, alloy disc, double wall, pin joint, eyelets, 24mm, 32h
FRONT HUBSpecialized Hi Lo disc, QR, 32h
REAR HUBSpecialized Hi Lo disc, double sealed cartridge bearing, QR, 32h
SPOKES1.8mm (15g) stainless
FRONT TIRESpecialized "The Captain" Sport, 60 TPI, wire bead, 26x2.0"
REAR TIRESpecialized "The Captain" Sport, 60 TPI, wire bead, 26x2.0"
INNER TUBESUltralight presta valve
SADDLESpecialized Women's BG Windie XC, 143mm width
SEATPOST6061 alloy, 2-bolt micro adjust, setback head, 30.9mm, 350mm
SEAT BINDER34.9mm clamp ID, 7050 hard annodized alloy collar w/ QR, black
priside er 10 000 ink frakt i Norge.
Re: FS: Specialized Myka FSR Elite 2011 [Re: gran] #1957887 12/05/2015 08:20
gran Offline OP
Størrelse er Medium/Large passer for damer fra 165cm og oppover till 175/180cm ?
Re: FS: Specialized Myka FSR Elite 2011 [Re: gran] #1958203 12/05/2015 16:42
gran Offline OP
Har fått bud på 8000....
Re: FS: Specialized Myka FSR Elite 2011 [Re: gran] #1958207 12/05/2015 16:47
gran Offline OP
Re: FS: Specialized Myka FSR Elite 2011 [Re: gran] #1959895 17/05/2015 11:51
gran Offline OP
Solgt.
