Fin rittfulldemper selges. Sykkelen kommer rett fra service hvor alle slitedeler er byttet.
Str L/19"
Selges 19000:)
Etter en velt er det ett lite hakk i overrør. Må ikke repareres og har ikke noe å si for bruk av sykkelen. Knappt synlig.
Noe bruks riper er det men ser veldig hel og fin ut.
Har også en Scale 900 RC til salg str L. 34000. kr.
Specifications
Model Year2013
Riding TypeCross Country
Sizes and GeometryS (High/Low), M (High/Low), L (High/Low), XL (High/Low) View Geometry
Frame Material29" Carbon
Rear Travel100mm
Rear ShockScott DT Nude 2, 3 Modes Lockout-Traction-Descent, Rebound Adjust
ForkFox 32 Float 29 Factory CTD Air CTD Damper with 3 Modes, 15mm Quick Release Axle, Tapered Steerer, Rebound Adjust
Fork Travel100mm
Head Tube DiameterTapered 1.5" to 1-1/8"
HeadsetRitchey Pro Tapered Semi Integrated, OD 50/61mm, ID 44/55mm
HandlebarSyncros FL1.5 T-Bar, Alloy 7050 D.B., T Shape Flat, 9 , 700mm
StemSyncros FL1.5 7050 Alloy, Oversize 31.8mm, 1-1/8", 6 Angle
GripsSyncros Pro Lock On
BrakesShimano XT BR-M785 Disc, 180mm Front and 160mm Rear SM-RT64 CL Rotors
Brake LeversShimano XT BL-M785 Disc
ShiftersShimano XT SL-M780-I, Rapidfire Plus, 2-Way Release, I-Spec Clamp
Front DerailleurShimano XT FD-M785-E / DM
Rear DerailleurShimano XT RD-M786 SGS Shadow PlusType, 20-Speed
ISCG Tabs
Chainguide
CranksShimano XT FC-M785 Hollowtech 2
Chainrings38Ax24A Tooth
Bottom BracketShimano SM-BB71-41A, Shell 41x89.5mm
PedalsN/A
ChainShimano CN-HG74
CassetteShimano XT CS-M771-10, 11-36 Tooth
RimsSyncros DT Swiss XR 2.0 29", 28 Hole, Tubeless Ready
HubsSyncros XR 2.0 29 CL Made by DT Swiss Front, Syncros XR 2.0 29 CL RWS Made by DT Swiss Rear
SpokesDT Swiss Super Comp
TiresSchwalbe Rocket Ron EVO 29"x2.25", 127EPI Kevlar Bead, Tubeless Ready, Pace Star Compound
SaddleSyncros XR1.5, Titanium Rails
SeatpostSyncros FL1.5
Seat Post Diameter31.6mm
Seatpost Clamp
Rear Dropout / Hub DimensionsIDS SL for 142mm x 12mm
Max. Tire Size
Bottle Cage MountsYes
ColorsBlack
WarrantyFive Year
Weight24 lb 14.6 oz (11.3 kg)
Tilstand: Brukt
Sykkeltype: Fulldemper
