Selger min lite brukte 900 RC. Str L/19"
34000 kr.
Specifications
Model Year 2014
Riding Type Cross Country
Sizes and Geometry S, M, L, XL View Geometry
Frame Material Carbon
Rear Travel N/A
Rear Shock N/A
Fork RockShox SID 29 RL3 Air, DNA3 Custom Damper with 3 Modes, 15mm QR Axle, Tapered Steerer, Rebound Adjust, with Scott RideLoc Remote Technology
Fork Travel 100mm
Head Tube Diameter Tapered
Headset Ritchey Pro Tapered 1.5" to 1-1/8", Semi Integrated OD 50/61mm / ID 44/55mm
Handlebar Ritchey Carbon WCS 2X, T Shape Flat, 9°, 700mm
Stem Ritchey WCS C-260, Oversize 31.8mm, 1-1/8", 6° Angle, Length on Size: S-70mm, M-80mm, L-90mm, XL-100mm
Grips Syncros Silicone
Brakes Shimano XTR M987 Disc, 180mm Front and 160mm Rear SM-RT67 CL Rotors
Brake Levers Shimano XTR XC M987 Disc
Shifters SRAM X01 Trigger, Right Only, Multi Adjust, with Carbon Cap
Front Derailleur N/A
Rear Derailleur SRAM XX1, 11-Speed
ISCG Tabs N/A
Chainguide N/A
Cranks SRAM XX1 GXP PF, Carbon Arm, QF 156
Chainrings 32 Tooth
Bottom Bracket SRAM GXP PF Integrated, Shell 41x89.5mm
Pedals N/A
Chain SRAM PC XX1
Cassette SRAM X01, XG1195, 10-42 Tooth
Rims Syncros XR RC, 28 Hole, Tubeless Ready, 29"
Hubs Syncros XR RC CL Made by DT Swiss Front // Syncros XR RC CL RWS XD Body Made by DT Swiss Rear
Spokes DT Swiss Aero Comp
Tires Schwalbe Rocket Ron EVO, 29"x 2.1", 127EPI Kevlar Bead, Tubeless Ready, PaceStar Compound
Saddle Ritchey WCS Streem Ti Rails
Seatpost Carbon 2B SDS
Seat Post Diameter 34.9mm
Seatpost Clamp Standard
Rear Dropout / Hub Dimensions Interchangeable IDS SL for 142mm x 12mm
Max. Tire Size
Bottle Cage Mounts Yes
Colors White/Black/Yellow
Warranty 5 Years for Frames and Swingarms
Weight 19 lb 6.4 oz (8.8 kg)
Kan kontaktes på 91 73 74 28 eller pm.
