Letteste 150 mm fulldemper i verden. Kun drøyt 10 kg tung. Svært god bakdemper. Veldig lite brukt.
Str. Medium. Passer for 170 - 183 cm.
Kjøpte den ubrukt i butikk juli 2013. Etter det har jeg brukt den samtidig som har har hatt 3 andre terrengsykler som jeg har brukt mer enn denne.
Kan ses, testes og hentes i Oslo.
Se annonse med flere bilder på Finn.no Mobil 92065999 - tormagnus.no@gmail.com
The Genius is a full suspension bike designed to handle any trail, any time. It’s the ultimate trail bike suitable for marathons and multi-day stage races. IMP4 carbon technology makes the bike extremely lightweight and stiff, while the Equalizer2 shock allows the rider three separate travel settings that can be accessed via the handlebar mounted TwinLoc lever. The HMX carbon fibre Scott Genius 10 2012 Mountain Bike is equipped with SRAM X0 to create the lightest 150 mm travel trail bike available.
SCOTT’s patented and unique TwinLoc lever allows the rider to keep both hands on the handlebars while selecting the desired travel settings or fully locking the suspension. Riders can switch between full travel with 150mm, Traction Mode with 95mm of rear travel, and complete lock out of both the fork and the Equalizer2 TC shock.
Frame:
Genius Carbon, IMP4 Technology, HMX NET, carbon swingarm, carbon dropouts with replaceable mech hanger, sealed aircraft bearings, 150mm rear wheel travel
Rear Shock:
Scott Equalizer 2 with 3 modes – Lockout, Traction and Full Travel, sag indicator, dual rebound adjustable
Fork:
Fox 32 Talas FIT RL, 15mm thru-axle, lockout, rebound adjustable, 2 travel position, 150-120mm travel
Front Derailleur:
SRAM X0 direct mount
Rear Derailleur:
SRAM X0 Carbon long cage
Number of Gears:
20
Shifters:
SRAM X0 trigger multi adjustable matchmaker clamp
Chainset:
SRAM X0 GXP Carbon
Chainrings:
39/26 tooth
Bottom Bracket:
SRAM GXP cartridge
Cassette:
SRAM PG1070 11-36 tooth 10-speed
Chain:
SRAM PC1051
Pedals:
None
Front Brake:
Avid Elixir 9RS Carbon, 180mm HS1 rotor
Rear Brake:
Brake Levers:
Handlebars:
Syncros FL Carbon, 20mm rise, 680mm
Stem:
Syncros FL, 6 degree angle
Headset:
Ritchey Pro, semi-integrated
Grips:
Scott lockon
Rims:
DT Swiss XR15 Disc, tubeless ready
Front Hub:
DT Swiss XR15 Disc IT, 15mm
Rear Hub:
DT Swiss XR15 Disc IT, 10mm RWS QR
Spokes:
DT Swiss Super Comp Black
Front Tyre:
Schwalbe Nobby Nic Evo, 26×2.25, Kevlar bead, tubeless ready, Pacestar compound
Rear Tyre:
Saddle:
Selle Italia SLR XP Team Edition, Vanox rails
Seatpost:
Syncros FL Carbon
Extra Features:
Remote Shock System: Scott Twinloc remote lever, front and rear lockout activated by one lever – Travel adjust: Lockout/95mm/150mm
