Selger min meget lite brukte 2015 modell. Har brukt den fem turer og totalt ca 8 mil. Den et spekket som følger:
FRAME FACT 11m carbon, 29" Trail Geometry, FACT IS construction, tapered headtube, PF30 BB, internal Command Post IR routing, 142mm dropouts, sealed cartridge bearing pivots, replaceable derailleur hanger, 130mm travel
REAR SHOCK FOX/Specialized remote Brain w/ AUTOSAG, smaller Brain reservoir, Kashima coating, inertia valve w/ Trail Tune, BrainFade adjust, 195x48mm
FORK Custom RockShox Pike RCT3 29, Solo Air spring, tapered alloy steerer, w/ lockout, compression, rebound adj., 15mm thru-axle, 130mm travel
HEADSET 1-1/8" and 1-1/2" threadless, Campy style upper with 1-1/2" lower, cartridge bearings
STEM Syntace F109, 6-degree rise
HANDLEBARS Specialized XC, mini rise, carbon, 8-backsweep, 6-upsweep, 10mm rise, 31.8mm
GRIPS Specialized Sip Grip, light lock-on, half-waffle, S/M: regular thickness, Others: XL
FRONT BRAKE Shimano XTR, magnesium caliper, Ti-metal pads, Ice Tech rotor, S/M: 180mm, Others: 200mm
REAR BRAKE Shimano XTR, magnesium caliper, Ti-metal pads, Ice Tech rotor, S/M: 160mm, Others: 180mm
BRAKE LEVERS Shimano XTR, carbon lever
REAR DERAILLEUR SRAM XX1, 11-speed
SHIFT LEVERS SRAM XX1, 11-speed, trigger
CASSETTE SRAM XX1, 11-speed, 10-42
CHAIN SRAM PC-XX1, 11-speed, w/ PowerLink
CRANKSET S-Works FACT carbon, custom XX1 chainring, OSBB, 30T
BOTTOM BRACKET Praxis, PF30, OS press-in bearings, sealed cartridge
PEDALS Resin test ride, w/ toe clips, CEN std.
RIMS Roval Control SL 29, carbon disc, 22mm internal width, 24/28h
FRONT HUB Roval Control SL 29, alloy hub body w/ Labyrinth design, 15mm thru-axle, 24h
REAR HUB Roval Control SL 29 142+, DT Swiss Star Ratchet, XX1 driver body, 12mm thru-axle, 28h
SPOKES DT Swiss Revolution
FRONT TIRE Specialized Purgatory Control, 60TPI, 2Bliss Ready, folding bead, dual-compound, 29x2.3"
REAR TIRE Specialized Ground Control, 60 TPI, 2Bliss Ready, folding bead, 29x2.3"
INNER TUBES Tubeless
SADDLE Body Geometry Henge Expert, hollow Ti rails, 143mm
SEATPOST Command Post IR w/ new SRL lever, 3-position height adjustable, alien head design, bottom mount cable routing, w/ remote adjust SRL, 30.9mm, S: 100mm travel, Others: 125mm
SEAT BINDER Specialized 7050 alloy, single bolt, 34.9mm
Brukte den da jeg syklet trekanten(se bilder på
http://www.terjeaamodt.com/blog/) og hadde et ublidt møte med en stein som lagde noen riper i venstre kjedestag, men kun kosmetisk. Knakk også bremsehendel, men det er ordnet nå.
Dekkene er satt opp tubeless. Dette er en helt råååååå sykkel som jeg gjerne skulle beholdt selv, men fikk sponsoravtale med annet merke så da er det for dumt å bare ha denne stående.
Pris? Selges for vanvittige 45.000,-!!! Kan sende, men kjøper betaler frakt.
Ønske du mer info ta kontakt på PM.
