Nypris 76.000.-
Selges 14.000.-
140mm vandring
26" hjul
Størrelse Medium ca 170-180 høyde, jeg er 173ish og sitter veldig bra.
Helt rå stisykkel som spiser alt. står med Hans dampf dekk, ny xx kassett og kjede i fjor høst. klar for bruk
Noen bruksmerker på krank etter bruk 2 sesonger er det eneste man kan sette fingeren på.
Technical Specifications
FRAME
S-Works Stumpjumper FSR FACT IS 10M carbon main triangle and seatstays with carbon drive dropout, M5 alloy chainstays, full cartridge bearing pivots, 140mm travel
REAR SHOCK
Specialized/Fox AFR Brain Shock w/ remote Trail Tune inertia valve, rebound adj. and Brain Fade, 7.875x1.9" Integrated cartridge bearing shock mount.
FORK
Specialized Future Shock S140TA, 140-115mm travel adjust, Trail Tune, Brain Fade, rebound adj., carbon 1-1/8" to 1.5" steerer
HEADSET
1-1/8" Threadless, 1 1/2" lower, Campy style
STEM
Syntace F109 31.8mm
HANDLEBARS
Specialized XC Carbon riser bar, 31.8mm, 660mm wide, 8 degree back sweep, 6 degree up
GRIPS
Specialized waffle lock on grip (S/M) Specialized Thick lock on grip (L/XL)
FRONT BRAKE
Custom Avid XX R, alloy backed semi-met pads, magnesium caliper and lever body w/ carbon blade, ti hardware package, tool-less reach and pad contact adj, S/M: 185mm, L/XL: 203mm rotor
REAR BRAKE
Custom Avid XX R, alloy backed semi-met pads, magnesium caliper and lever body w/ carbon blade, ti hardware package, tool-less reach and pad contact adj, S/M: 160mm, L/XL: 185mm rotor
BRAKE LEVERS
Custom Avid XX R with tool-less reach and pad contact adj
FRONT DERAILLEUR
Shimano M971 XTR, DMD, top swing, dual pull
REAR DERAILLEUR
SRAM XX, 10-speed, standard cage
SHIFT LEVERS
SRAM XX carbon trigger (rear)/SRAM XO (front)
CASSETTE
SRAM XX, 10-speed, 11-36t
CHAIN
SRAM PC-1090, 10-speed
CRANKSET
S-Works OS carbon crank, S: 170mm, Others: 175mm
CHAINRINGS
22/32/44
BOTTOM BRACKET
PEDALS
None
RIMS
Roval Control SL, disc, 24mm
FRONT HUB
Roval Control SL, OS 28mm axle caps
REAR HUB
Roval Control SL
SPOKES
FRONT TIRE
S-Works Purgatory, 26x2.2", 120 TPI, tubeless ready aramid bead, dual compound
REAR TIRE
The Captain Control, 26x2.0", 60 TPI, tubeless ready aramid bead, dual compound
INNER TUBES
Ultralight presta valve
SADDLE
Specialized Phenom SL, Ti rails, thin foam, S/M: 130mm, L/XL: 143mm
SEATPOST
S-Works Carbon, 30.9mm, single-bolt head, S/M: 350mm, L/XL: 400mm
