Jeg har to sett ubrukte, i emballasje for Shimano XT/XTR (før 2002), Hope Mono M4 eller Grimeca system bremser. Jeg kjøpte feil fordi jeg hadde nyere XT bremser.. Hvis noen kan bruke disse beleggene så går begge pakkene for en poløl..
Compound: Ceramic Pro Spring(s) Included These soft organic ceramic fiber disc brake pads are carbonized. The ceramic compound insulates the brake system from friction heat up to 400oC. The result is a very powerful, quiet pad with extremely low heat generation which all but eliminates the chances of brake fade.
Details Upgrade on original fitted pads DIN 79100 Standard Approved Organic Compound contains no metal material Reduces damage to rotor Carbonized compound reduces brake fading Ceramic Fiber insulates brake system from friction heat
