Surly Krampus 29+
Surly Krampus 29+ #1804041 10/06/2014 20:22
lrm Offline OP
Maratonmannen
Maratonmannen
Surly Krampus 29+ str.M
Har ikke hat tid til å teste sykkelen mer en 4 turer. Det er faktisk en overraskende lettsyklet sykkel. Går ganke bra oppover, veldig moro på sti og fungerer veldig bra på snø:) Så sykkelen ser ut som ny:)
Frameset
Frame
Surly Krampus, Surly 4130 CroMoly steel. Main Triangle TIG-welded, custom butted. Sweet CS Yoke.
Fork
Surly Krampus, TIG-welded custom tapered butted 4130 CroMoly, 100–120mm suspension corrected, 1-1/8˝ steerer tube, 203mm disc brake clearance
Seatpost clamp
Surly Stainless, 30.0mm
Drivetrain
Crankset
Shimano ZEE, 175. 170 on small
Bottom Bracket
Front Derailleur
MRP 1x guide. BB mount, yep
Rear Derailleur
Shimano SLX/Shadow+ RD-M675, Black
Cog or Cassette
SRAM GG-1070, 10-speed. 11-12-14-16-18-21-24-28-32-36t
Chain
KMC x10, Silver
Components
Headset
Cane Creek, 40 series for 44mm
Brakes
Avid BB7, 180/160 HS rotors
Brake Levers
Avid FR-5, Black
Shifters
Shimano SLX, 10-speed RH
Stem
Kalloy, 31.8mm. 60/70/80/90mm length
Handlebar
Salsa Wammy, 780mm width. 11° bend, flat
Saddle
Velo VL2155, steel rails
Seatpost
Kalloy SP-324
Extras
Chain guide
Wheels
Front Hub
Surly Ultra New Disc, 32h. 6-bolt disc. Black
Rear Hub
Shimano FH-M529, 32h. Disc. Black
Rims
Surly Rabbit Hole 29+, 700c x 50mm w/holes
Spokes
DT Swiss, 14g
Tires
Surly Knard 29 x 3˝, 27tpi
Selges: 10000,-
Re: Surly Krampus 29+ [Re: lrm] #1807621 17/06/2014 14:07
gtv Offline
Hei,
Er det plass til 5.0" dekk på denne?
Orbea Wild FS
Devinci Atlas Karbon
Cannondale Flash 29"
Felt Nine Race 29" custom
When you stop doing things for fun you might as well be dead
Re: Surly Krampus 29+ [Re: lrm] #1807718 17/06/2014 16:16
Nanok Offline
Nei. Maks 3.0" men med 29+ diameter.
McNulty
