Selger min Mongoose teocali str M. Sykkelen er brukt 5 ganger de siste to sesongene.
Nye Maxxis Ardent 2.4 dekk i høst. Drivverk skiftet i fjor sommer og brukt få ganger etterpå.
Bakhjulet er byttet til Mavic Crossride.
Spec:
Frame: Suspension
Fork: Rock Shox Sektor RL 150 mm travel, Solo Air spring, lockout, rebound and 15 mm Maxle Lite thru axle.
Rear Shock: Ario 3.2 , air spring, rebound and lock out, 200x57 mm w/ 19x8 mm hardware.
Spokes: 14g Stainless
Tires: Kenda Excavator 26x2.35 front / 2.1 rear Dual Tread Compound, folding bead.
Crankset: FSA Comet 27/39T alloy
Bottom Bracket: FSA MegaExo external bearing
Chain: KMC X10 w/ Missing Link connector
Front Derailleur: Shimano SLX
Rear Derailleur: SRAM X.9 medium cage
Shifters: SRAM X.7 2x10 speed
Handlebar: Kore Torsion Race Riser Handlebar 710 x 31.8 x 20 rise x 5 deg BB Black.
Stem: Kore B-52 0 deg. K34 Stem 65x31.8x28.6 BB Black.
Headset: FSA ZS Taper w/ACB bearigns (1.125" upper 1.5" lower).
Brake Rotor: Avid Elixir 3 hydraulic disc w/ 185 mm front /160mm rear rotors.
Brake Levers: Avid Elixir 3
Saddle: Kore T-Beam, 6061 forged alloy rail
Seat Post: Kore T-Beam / I-Beam 6061 Seatpost 31.6 x 350 Satin Silver head, zero offset, BB Black shaft.
Følger med shimano 520 pedaler, 3 ekstra dekk, to ekstra stem og ekstra sete med pinne.
Pris: 8000 / bud.
Bilde:
http://stwww.bikemag.com/files/2010/08/dsc00333.jpg
