Scott genius lt20
Scott genius lt20 #1778454 29/04/2014 19:06
Registrert: Apr 2006
Juen Offline OP
Fantastisk stisykkel, karbonramme, Long travel versjon med 180mm vandring fram og bak med mulighet for lockout, senkes til 140mm på 1 sekund. Nypris 40 000 kr. Veier kun 14 kg. Selges uten pedaler.
Nylig service gaffel, skiftet styre til boobar 78cm, ny krans, nylig luftet og skiftet bremseveske, hans dampf 2,4. Bilder sendes per epost, ta kontakt på jogo163@hotmail.com
Vurderes solgt for 16000,- sykkelen befinner seg på Oppdal.
Original specs:
Ramme:Genius LT Carbon Concept / Carbon mainframe IMP5 technology / HMF NET / Tapered HeaDTube / Alloy 6061 Double butted swingarm / IDS SL 12x142mm Dropout BB Height adjustable / ISCG05 Adapter 185mm rear travel
Bak demper:Scott Equalizer 3 / 3 modes: Lockout - Traction Control - All Travel Sag indicator / Dual rebound adjustable
Gaffel:Rock Shox Lyrik RLR / Scott Custom Air Spring / Remote Lockout / Tapered steerer IS Rebound adjustable / 20mm Maxle 2 step Travel adjustable / 180 - 140mm travel
Framgir:SRAM X.7 / DM S3
Bak gir:SRAM X.9 / long cageNumber of Gears:30Shifters:SRAM X.7 Trigger / adjustable clamp
Chainset:SRAM X.9 3.3 / GXP PF
Chainrings:44A x 33A x 22A T
Bottom Bracket:Sram GXP PF integrated / shell 41x89.5mm
Kassett:SRAM PG 1070 / 12-36 TChain:SRAM PC 1031Pedals:None supplied
Fram brems:Avid Elixir R with 203mm rotor
Bak brems:Avid Elixir R with 185mm rotor
Bremsehendler:Avid Elixir RHandlebars:Scott Pilot 20 Pro / 7075 Alloy 20mm rise / 700mm
Stem:Scott AM / 4 bolt Oversize 31.8mm 1 1/8" / 6 degrees angle
Headset:Syncros AM Pro / Tapered 1.5" - 1 1/8" semi integrated 50/61mm
Håndtak:Scott Lock-on gripsRims:DT Swiss AM 20 / 32H / Tubeless ready
Front Hub:DT Swiss AM 20 Disc IT 20mmRear Hub:DT Swiss AM 20 Disc IT with 12mm RWS / 12 x 142mm
Spokes:DT Swiss Champion Black 1.8mmFront
Dekk:Schwalbe Fat Albert EVO / 26 x 2.4 67EPI / Kevlar / Snake Skin / Tubeless ready Compound Front: Trail Star / Rear: Pace StarRear
Sete:Scott AM / 7mm CROM rails
Setepinne:Crankbrothers Joplin 4 adjustable / 31.6mm
Vekt:14.00 kg
Tilstand: Brukt
Re: Scott genius lt20 [Re: Juen] #1778466 29/04/2014 19:30
Juen Offline OP
Også skiftet til 2x10 og kjedefører
Re: Scott genius lt20 [Re: Juen] #1780255 02/05/2014 20:45
Registrert: May 2013
pcn Offline
Hvor stor er rammen?
Re: Scott genius lt20 [Re: Juen] #1806580 15/06/2014 21:22
Juen Offline OP
Bump. Ny shock før salg, nytt kjede og kjedefører satt på.
Str M
Pris vurderes ved rask avgjørelse. Dette er en meget billig carbonsykkel
Re: Scott genius lt20 [Re: Juen] #1857492 15/09/2014 19:41
Grillfest Offline
Hei
Er denne fortsatt til salgs?
Sikker s... Sykling?
