Sykkel som er fantastisk til klatring og nedkjøring. Den er str Medium og har hydraulikksete som er helt uunnværlig.
Helt strøken. Brukt 7 dager. Selges 20000,-
Ring på 98219498 for spm.
Sender bilder på forespørsel (klarte ikke legge inn i annonsen...)
Les review på : http://www.vitalmtb.com/product/guide/Bikes,3/GT/Force-LE,11760
Teknisk :
Rear Travel 150mm
Rear Shock Fox Racing Shox Float CTD BV Adjust, 7.5"x2" Air Shock, Rebound Adjust and Lockout
Fork Fox Racing Shox 34 Float 160 RLC FIT, Fit Damper, 20x110mm Thru Axle, Adjustable Rebound and Compression, Lockout, Tapered Alloy Steerer
Fork Travel 160mm
Head Tube Diameter 1-1/8" to 1-1/2" Tapered
Headset Cane Creek Angleset EC44xEC49 w/ +/- 1° Offset Cup
Handlebar Kore OCD-TR, Triple Butted AL7050, 740mm Width, 15mm Rise, 31.8mm Clamp
Stem Easton Haven
Grips GT Wings with Waffle Lock-On
Brakes Formula T1, with Alloy Carrier 180mm Rotor
Brake Levers Formula T1 with TFRA & FCS
Shifters Shimano Deore XT, SL-M780, Rapid Fire
Front Derailleur Shimano Deore XT, FD-M785
Rear Derailleur Shimano Deore XT Shadow Plus, RD-M786-GS
Chainguide Lower 2X Guide
Cranks RaceFace Turbine
Chainrings 36/24Tooth with Bashguard
Bottom Bracket RaceFace X-Type
Chain KMC X10
Cassette Shimano Deore XT, CS-M771-10, 10-Speed, 11-36 Tooth
Rims Easton Haven Wheelset
Hubs Easton Haven Wheelset
Spokes Easton Haven Wheelset
Tires Maxxis Ardent, 26" x 2.4" Front, 26" x 2.25" Rear, with Folding Bead and Exo Protection
Saddle WTB Silverado Race SL
Seatpost RockShox Reverb, Height Adjust with Hydraulic Remote
Seat Post Diameter
Seatpost Clamp All Terra Alloy
Rear Dropout / Hub Dimensions 142 x 12mm
Weight 31 lb 11 oz (14.4 kg)
