2012 Lapierre X-flow 612 str L selges. Sykkelen ble kjøpt ny våren 2012 og har i tillegg blitt brukt lite sesongen 2013.
Opprinnelig utstyr: Frame: X-Flow 612 Full Carbon PendBox 120mm Rear Shock: Fox Float RP2 HV Boost Valve for PendBox Fork: Fox 32 RLC FIT 120mm Front Derailleur: Shimano SLX M660E Rear Derailleur: Shimano XT M780 Long Cage 10-speed Number of Gears: 30 Shifters: Shimano SLX Chainset: Shimano XT M780 170mm Chainrings: 34/32/42 Bottom Bracket: Shimano BB7141A Cassette: Shimano Deore HG62 11-36t 10-speed Chain: KMC X10 Front Brake: Formula RX 180 PM Black/ Green Rear Brake: Formula RX 160 IS Black/ Green Brake Levers: Formula RX Handlebars: Lapierre Pro 31.8 20×660mm 2012 Stem: Lapierre AMR 31.8X90mm 2012 Headset: Alloy Semi- Integrated Cartridge Tapered Grips: Lapierre XC Pro Straight 31.6×350mm Rims: Easton EA70 XCT Black Front Hub: Easton EA70 Rear Hub: Easton EA70 Front Tyre: Continental Mountain King UST 26×2.2 Rear Tyre: Continental X King UST 26×2.2 Saddle: Fizik Gobi XM Mg Black/ White 2012 Seatpost: Lapierre XC Pro Straight 31.6350mm Weight: 11.8Kg ( In size 46 without pedals)
Setet er skiftet ut til et Selle Italia SLR XC og det er satt på Maxxis Ikon 2.2 dekk som nesten ikke er brukt. Sykkelen har nylig blitt grundig overhalt.
Re: Rask stisykkel i karbon selges, Lapierre X-Flow612
[Re: bendixen]
#174362710/02/201415:12
