Scott Voltage FR 20 - 2011 - Billig
Scott Voltage FR 20 - 2011 - Billig #1698598 13/10/2013 10:34
timmh Offline OP
Damekjørt Scott Voltage FR 20 selges. 8000,-
Størrelse Short. Passer ryttere fra 155 - 175.
Minimalt brukt i to sesonger. Ikke vært utleiesykkel.
Sykkelen har bruksmerker, men ingen skader. Ingen skade på innerbein gaffel eller bulker på felgene.
Befinner seg i Trondheim. Henting foretrekkes, men har sykkeleske og kan sendes.
Ta kontakt på e-post / telefon:
torivar.melling(a)gmail.com / 90662483
Info:
Frame: Voltage FR Alloy 6061 hydroformed tubing Slopestyle & Park geometryISCG & ISCG05 tabs / HeaDTube for 1.5" IDS interchangeable Dropout with 12mm thru axle 160-180mm travel
Rear Shock: Fox VAN R coil spring preload Speed sensitive compression & rebound damping / Rebound adjustable
Fork: RockShox Domain Dual crown RC / Coil / Rebound adjustable / Maxle Lite 20mm Alloy steerer / 200mm travel
Rear Derailleur: SRAM X.7 / short cage
Number of Gears: 9
Shifters: SRAM X5 / Trigger Shifter
Chainset: Truvativ Hussefelt 1.0 165mm crankarm
Chainrings: 36T chainring
Bottom Bracket: Truvativ HowitzerXR 73mm shell
Cassette: SRAM PG-950 / 11-28 T
Chain: Shimano CN-HG53
Pedals: BBB Flat pedal with replaceable pins
Front Brake: Avid Elixir 5 Disc with 203mm rotor
Rear Brake: Avid Elixir 5 Disc with 203mm rotor
Brake Levers: Avid Elixir 5 Disc
Handlebars: Scott Pilot FR 1 Pro / Double butted / 20mm rise, 750mm
Stem: Truvativ Hussefelt / Oversize 31.8mm 1 1/8" / 0 degrees angle, 40mm length
Headset: FSA Orbit E 1.5R, alloy cups, 1.5" Reducer to 11/8", semi-integrated
Grips: Scott Lock-on grips
Rims: Alex FR 32 / 32H / DH disc rim
Front Hub: Scott Comp 20mm thru axle
Rear Hub: Scott DHL-135 12mm thru axle / 135mm wide
Spokes: DT Swiss Champion black 2.0mm
Saddle: Scott Voltage FR
Seatpost: Scott DJ zero offset / 31.6mm
Weight: 18.10 kg / 39.87 lbs approx
Redigert av timmh; 13/10/2013 10:35.
Re: Scott Voltage FR 20 - 2011 - Billig [Re: timmh] #1699442 14/10/2013 21:02
timmh Offline OP
Solgt.
