Specialized S-Works Stumpjumper HT 29 XTR 2013
Specialized S-Works Stumpjumper HT 29 XTR 2013 #1684262 18/09/2013 08:30
Høggern Offline OP
Jeg selger unna råtassen min!
Rammestørrelsen er 19.5 og sykkelen har alt av originale deler.
Jeg har bare fått syklet 3 MTB ritt i år grunnet sykdom i våres.
http://rittranking.merida.no/person/2184/view
Selger også MED treningshjulene mine Roval Controll 29. Veil. 5700kr
Sykkelen har akkurat vært på service. Alt av slite deler har blitt byttet.
Specialized S-Works Stumpjumper HT Carbon 29 XTR
Ramme:
FACT 11m carbon, 29" geometry, tapered HT,
carbon PF30 BB,
hollow carbon dropouts, replaceable alloy rear derailleur hanger
Gaffel:
Custom RockShox SID World Cup 29 Brain, inertia valve damper,
Solo air spring, tapered carbon crown/steerer,
top-mount Brain Fade and rebound adj.,
QR, 15.5": 80mm, 17.5/19/21": 90mm travel
Headset:
1-1/8 and 1-1/2" threadless, Campy style upper with 1-1/2" lower, cartridge bearings
Bremser:
Shimano XTR hydraulic disc, post mount,
Ti/metal pad, Ice Tech, 160mm rotor
Bremsehendler:
Shimano XTR 985 hydraulic, w/I-Spec clamps
Girhendler:
Shimano XTR, 10-speed, w/ I-Spec clamps
Kranksett:
S-Works OS carbon, 10-speed XC double,
custom SRAM spider/rings 15.5": 170mm, Others: 175mm
Kranklager:
SRAM PF30, OS press-in bearing, sealed cartridge
Frontgir:
XTR, 34.9 clamp, down-swing, dual-pull
Bakgir:
Shimano Shadow Plus XTR, 10-speed, GS mid-cage
Kassett:
Shimano XTR M980, 10-speed, 11-36
Hjulsett:
Roval Control SL 29, carbon disc, 28mm wide, 32h
Pris 37000kr
Jeg er kun interessert i seriøse bud.
Ta kontakt for en hyggelig sykkel prat!
Re: Specialized S-Works Stumpjumper HT 29 XTR 2013 [Re: Høggern] #1687978 24/09/2013 08:30
Høggern Offline OP
Re: Specialized S-Works Stumpjumper HT 29 XTR 2013 [Re: Høggern] #1689127 25/09/2013 20:23
Høggern Offline OP
34999kr!
Re: Specialized S-Works Stumpjumper HT 29 XTR 2013 [Re: Høggern] #1690411 27/09/2013 19:00
Høggern Offline OP
Solgt
