Rammemateriale og komfort. Rare påstander.
Rammemateriale og komfort. Rare påstander. #1654218 06/08/2013 16:48
Registrert: Jan 2012
Akaly Offline OP
Hvorfor påstås det stadig at noen rammematerialer er mer komfortable enn andre? Dette har da vitterlig ingen basis i virkeligheten, og sykkelorakler som Sheldon Brown og Grant Petersen sier også det samme. Men selv her på Terrengsykkels forum får man høre det samme stadig vekk. Hvorfor?
Sitat: Sheldon Brown - http://sheldonbrown.com/frame-materials.html
Did you know that:
- Aluminum frames have a harsh ride?
- Titanium frames are soft and whippy?
- Steel frames go soft with age, but they have a nicer ride quality?
- England's Queen Elizabeth is a kingpin of the international drug trade?
All of the above statements are equally false.
There is an amazing amount of folkloric "conventional wisdom" about bicycle frames and materials that is widely disseminated, but has no basis in fact.
The reality is that you can make a good bike frame out of any of these metals, with any desired riding qualities, by selecting appropriate tubing diameters, wall thicknesses and frame geometry.
Sitat: Grant Petersen - https://docs.google.com/file/d/0BzehUKAztnO8ZjdhMmY3YmEtZmM0Ny00OTY0LThiOTItMjEzNWZlYjMxOTIx/edit?pli=1
Frames that claim shock absorption in this way are snake oil, and anybody who says they do is fooling—well, probably a lot of people. The power of the press and suggestion are strong. But don’t be fooled.
The same is true of forks. Shock-forks absorb shock. Rigid, straight bladed carbon forks don’t. Slender, curved steel forks with small diameter ends and low, small-radius bends may, must flex and absorb better than lesser forks, but the bulk of the absorption is still in the tire. It’s easier for low-pressure air to deform than it is for steel to.
Re: Rammemateriale og komfort. Rare påstander. [Re: Akaly] #1654230 06/08/2013 17:09
Registrert: Sep 2001
Espen Offline
Hele poenget er at ulike materialer gir en konstruktør ulike muligheter.
En aluramme må ha tykkere og stivere rør, fordi alu har mye lavere grense for varig deformering/utmatting.
En stålramme er motsatt. Fjærstål, tåler mye bevegelse.
Dermed er det enklere å lage en komfortabel stålramme enn å lage en komfortabel aluramme.
post@espenwettre.no
Re: Rammemateriale og komfort. Rare påstander. [Re: Akaly] #1654246 06/08/2013 17:34
Tange Offline
Flittig Bie
Flittig Bie
Nettopp og få konstruktører har behov for å jobbe mot det som blir ansett til å være materialets 'egenskaper'.
Det er vel kanskje carbon som er mest nøytralt sånt sett.
Re: Rammemateriale og komfort. Rare påstander. [Re: Akaly] #1654254 06/08/2013 17:51
Hæ? Offline
Navnet skjemmer ingen.
Tja. Salige Sheldon sier jo at det bare er tull at rammer får ulike egenskaper utfra hvilket materiale man bruker. Han sier det ligger i konstruksjonen og utnyttelsen av materialenes egenskaper.
Petersen snakker om absorbering av slag og rystelser. Og der har jo selvsagt dekkene mye mer å si på en landeveissykkel.
Re: Rammemateriale og komfort. Rare påstander. [Re: Akaly] #1654261 06/08/2013 18:04
krankdrev Offline
Karbon er en kompositt så det kan ikke lett sammenlignes med metaller da det har fiberetning. Metaller har (tilnærmet) like egenskaper i alle retninger.
Man må skille mellom egenskapene til selve materialet og på ei ramme bygget av dette. Det er liten tvil om at aluminiumsrammer ofte føles "harsh" mens stål er mer tilgivende.
Stål er stivere enn både titan og aluminium, aluminium har faktisk den laveste stivheten av de tre. Men aluminium er et lettmetall noe de to andre ikke er, derfor brukes mer materiale i ei aluminiumsramme enn i ei stålramme og resulatet blir ei stivere ramme. Særlig det faktum at rørene oftest har en mye større diameter gir dramatisk øket stivhet.
Titan har svært høy styrke og derfor brukes det minimalt materiale i ei slik ramme. Typisk mindre diameter på rørene (ganske likt stål) og tynne rørvegger (samme som stål eller enda litt tynnere).
Både stål og titan har gode utmattingsegenskaper, aluminium har ingen fast utmattingsgrense slik feks. stål har og er derfor langt mer utsatt for tretthetsbrudd. Strekkfastheten til de alulegeringene brukt på sykler er ganske høy, faktisk på høyde med mange lavlegerte stålkvaliteter men pga. faren for utmatting blir det risikabelt å bruke så lite materiale som i ei stålramme og man må uansett opp med rørdiametrene siden stivheten til selve materialet bare er ca. 1/3 av stivheten til stål. Karbon har jo omtrent overtatt helt på de letteste rammene til konkurransebruk, og det er kanskje like greit siden superlette alurammer havarerte ganske ofte pga. tretthet.
Re: Rammemateriale og komfort. Rare påstander. [Re: Akaly] #1654465 06/08/2013 22:02
Espen Offline
De beste stålrørene er jo sinnsyke materialer egentlig. Varmehardbart fjærstål.
Stiller i en helt annen liga enn alurørene som brukes i sykkelrammer.
Scot Nicol har en gammel og god artikkel om materialer.
http://www.strongframes.com/more_stuff/materials_tech/metallurgy/
post@espenwettre.no
Re: Rammemateriale og komfort. Rare påstander. [Re: Akaly] #1654488 06/08/2013 22:27
krankdrev Offline
Selv vanlig 4130 syns jeg er et flott materiale, i sin tid var dette high tech, i mellomkrigsåra var det bare noen få som kunne framstille dette stålet (bla. vårt broderfolk i øst) og det ble bla. brukt til flydeler.
Re: Rammemateriale og komfort. Rare påstander. [Re: Akaly] #1661616 16/08/2013 20:03
simenf Offline
Sheldons poeng er at man kan bygge inn de prioriterte egenskaper man ønsker i en sykkel med de fleste materialer.
Det er sikkert like mange eksempler på at stålrammer er stive og harde som karbon eller alu (jeg har en av dem). Det eneste er at stål har blitt brukt i rammer som har mer ettergivende egenskaper de siste 30 åra og derfor oppfattes stål som komfortable og ettergivende. Og det er jo sikkert fordi det oppfattes til å ikke kunne konkurrere med alu eller karbon på vekt i forhold til stivhet.
Re: Rammemateriale og komfort. Rare påstander. [Re: simenf] #1661645 16/08/2013 20:46
rockphotog Offline
Litt drodling fra min side, jeg er ingen ekspert på materialer:
En av fordelene med moderne karbonrammeproduksjon er jo at det er lett ("lett") å lage en ramme med ønskede egenskaper. Se for eksempel på kjedestag, som kanskje skal være tykke i sideretningen først, men ha litt vertikal fleks, så mere nøytral/rund siste halvdel. Slikt er mulig med stål også, men jeg tipper det er mye mer arbeid. Vil tro det er lettere å kontrollert deformere/forme aluminium enn stål/titan.
Så hvis vi bare kjøper (og det gjør jeg) at man får til det meste med de fleste materialer, velger man det materialet og metoden som gjør det enklest sett ut fra masseproduksjon.
Re: Rammemateriale og komfort. Rare påstander. [Re: Akaly] #1661727 17/08/2013 07:39
GeirK Offline
Sitat: Akaly
Fordi de fleste mennesker er lettlurte selvbedragre. Bare se på dem som også tror at de hører forskjell på Hi-Fi-forsterkere, blir friske av piller uten virkestoff, etc
- Robert Green Ingersoll
Re: Rammemateriale og komfort. Rare påstander. [Re: Akaly] #1661753 17/08/2013 08:45
bixit Offline
Hva mener du med, dem som tror de hører forskjell på Hi-Fi-forsterkere?
Jeg mener iallefall at det er lett å høre forskjell på endel forsterkere. Små billige forsterkere har tynn lyd, og trives på lave volum. Større forsterkere klarer å spille med mer dynamikk, samt mye høyere volum.
Jeg mener nå at det så og si er et faktum at det iallefall er typiske forskjeller på ramemmaterialer. Stål har holdbarhet, comfort, føles stødig, noe ekstra tyngde. Aluminium er lett, responsivt, ganske stivt. Carbon er mer high-tec, og brukt rett kan det dempe vibrasjoner, være lett, men samtidig responsivt.
Sanne klisjeer, spør du meg.
Re: Rammemateriale og komfort. Rare påstander. [Re: bixit] #1661771 17/08/2013 09:11
GeirK Offline
Sitat: bixit
Det er riktig at en større forsterker kan spille høyere og dermed gjengi dynamikk - fordi de kan levere mer effekt innenfor det lineære området. Utsagnet gjelder to forsterkere som begge opererer innenfor det lineære området og spiller med samme effekt på de samme høyttalerne. Men den diskusjonen tror jeg vi skal ta i en egen tråd.
Re: Rammemateriale og komfort. Rare påstander. [Re: bixit] #1661773 17/08/2013 09:18
GeirK Offline
Sitat: bixit
Hvordan konkluderer du med at dette er tilfelle?
Re: Rammemateriale og komfort. Rare påstander. [Re: bixit] #1661806 17/08/2013 11:02
Registrert: Jan 2006
KenR Offline
Sitat: bixit
Jeg mener iallefall at ...
Jeg mener nå at ...
Det gir seg vel selv hvor dette kommer fra?
Re: Rammemateriale og komfort. Rare påstander. [Re: Hæ?] #1662166 18/08/2013 09:54
M@rtin Offline
MaBose Infotainment
MaBose Infotainment
Sitat: Hæ?
Tyske Mountainbike Magazin gjennomførte i 2006 en blindfoldtest på kamuflerte HT-rammer av ulikt materiale der testerne skulle kåre den mest populære ramma samt gjette på rammenes materiale. Komponentene var identiske mens rammene var laget av stål, titan (Seven Sola), alu, scandium, alu/karbon og karbon (Scott) og popularitetsvinneren blant garva testere ble scandium-ramma: ren Taiwan-hyllevare fra Rose.de
Generelt var konklusjonen at testerne tok feil langt mer enn man hadde regnet med på forhånd og at de gikk etter gjengse klisjeer som gjerne knyttes til materialet - og bommet. Fasit: "bra" rammemateriale må på ingen måte også resultere i en bra ramme eller "dårlig" materiale nødvendigvis i en dårlig ramme.
Stemmer konstruksjon og geometri, faller også sykkelen i smak. Noe som tydeligvis også gjaldt for low-bling Rose-ramma den gang.
Martin
Re: Rammemateriale og komfort. Rare påstander. [Re: GeirK] #1662189 18/08/2013 10:56
bixit Offline
Sitat: GeirK
Sitat: bixit
Ja, det burde vært i en annen tråd. Men noe jeg selv synes det er greit å ha fokus på er størrelsen på lydbilde. Da om man vil ha lyden mellom høyttalerne på lavt volum, eller mer detaljer (som forhåpentligvis gir luftighet), og høyere volum.
