Scott Spark 900 Premium str. L 2013mod
Scott Spark 900 Premium str. L 2013mod #1612344 23/05/2013 20:16
lrm Offline OP
Maratonmannen
Maratonmannen
Har ikke brukt for min Spark 900 Premium mer i år så da kan den selges for å gjøre plass til nye 27,5" sykler ICON_SMILE
Den er kun brukt 2 ganger så det er så og si en ny sykkel. Hjulene er ubrukt.
Kan leveres med dobbel 38-26 utveksling eller orginal trippelkrank.
Spec:
Weight
10,5kg / 23,13lbs
Frame
SCOTT Spark 29 Carbon / IMP5 technology / HMX NET
BB 92 / Carbon swingarm with 160PM
U-Mono Link / Tapered Headtube
IDS SL dropouts for 142 x 12mm
BB height adj. / 100mm rear travel
Fork
FOX 32 Float 29 Factory CTD Air
CTD damper with 3 modes
15mm QR axle / tapered steerer
reb. Adj. / 100 mm travel
Remote System
SCOTT LTD suspension technology
Lock - Traction (travel / geo adj) - Descend
activate by Twinloc Remote Lever
Lockout - 70 - 100mm
Shock (Rear)
SCOTT DT Nude2 / 3 modes Lockout-TC-D
Ball joints / 165 x 38mm / reb. Adj.
Headset
Ritchey Pro Tapered 1.5" - 1 1/8"
semi integr. OD 50/61mm / ID 44/55mm
Derailleur (Rear)
Shimano XTR RD-M986 SGS
Shadow Plus Type / 30 Speed
Derailleur (Front)
Shimano XTR FD-M980-E / DM
Shifters
Shimano XTR SL-M980
Rapidfire Plus / 2 way release
Ispec clamp
Brake Levers
Shimano XTR XC M985 Disc
Brakes
Shimano XTR M985 Disc
180/F and 160/R mm SM-RT99 CL Rotor
Crankset
Shimano XTR FC-M980
hollowtech 2
42Ax32Ax24A T
BB-Set
Shimano SM-BB91-41A / shell 41x89.5mm
Handlebar
Syncros FL1.0 Carbon T-Bar
T shape flat / 9° / 700 mm
Syncros Pro lockon grips
H'stem
7050 carbon wrapped / oversize 31.8mm
1-1/8" / 6° angle
Pedals
nil
Seatpost
Syncros FL1.0 Carbon / 31.6mm
Seat
Syncros XR1.5 Crn-Tri rail
Hub (Front)
Syncros XR 1.5 29 CL / 15mm
made by DT Swiss
Hub (Rear)
Syncros XR 1.5 29 CL / 12 x 142 / RWS
made by DT Swiss
Chain
Shimano CN-HG94
Cassette
Shimano XTR CS-M980
11-36 T
Spokes
DT Swiss Super Comp
Rims
Syncros / DT Swiss XR 1.5 29
28H / Tubeless ready
Tires
Schwalbe Rocket Ron EVO
29 x 2.25 / 127EPI Kevlar Bead
Tubeless ready / Pace star compound
Selges for 33000,-
Re: Scott Spark 900 Premium str. L 2013mod [Re: lrm] #1614824 28/05/2013 08:10
lrm Offline OP
Maratonmannen
Maratonmannen
solgt
