Sykkel som er fantastisk til klatring og nedkjøring. Den er str Medium og har hydraulikksete som er helt uunnværlig.
Helt strøken. Brukt 7 dager. Selges 20000,-
Ring på 98219498 for spm.
Sender bilder på forespørsel (klarte ikke legge inn i annonsen...)
Les mer : http://www.jensonusa.com/!40zZTECGpoZILxJrNDB3ow!/GT-Sanction-10-Mountain-Bike-2012
Technical Specifications:
Frame
Monocoque/ hydroformed Xm Metal? frame (TT/DT/ST), 150mm Travel Independent Drivetrain? Suspension System w/ forged linkage, pivots, and bottom bracket, replaceable 142x12mm dropouts, 1 1/8" to 1 ½" tapered head tube w/ tT and DT gussets
Fork
Fox Racing Shox 36 Float 160 RLC FIT, 160mm travel, FIT damper, 20mm thru axle w/ adjustable rebound and compression, lockout, and tapered 1.5"- 1/8" alloy steerer
Rear Shock
Fox Shox Float RP23 w/ 150mm travel, adjustable rebound, compression, and lockout
Crank
SRAM X9, 36/22T w/ bashguard
Bottom Bracket
SRAM GXP
Shifters
Shimano Deore XT, Rapidfire
Cog Set
Shimano CS- M771 11-36T, 10 speed
Chain
KMC X10, 10 speed
Front Derailleur
Shimano Deore XT, 2x10
Rear Derailleur
Shimano XTR Shadow RD+
Wheels
DT Swiss E2000 wheelset, 32H
Tires
Maxxis Ardent, 2.4"/ 2.25" (F/R), Folding bead
Pedals
ALL TERRA Slimline Flat Pedal, Sealed Cartridge Bearings
Brakes
Formula The One, 180mm Rotors
Brake Levers
Formula The One
Handlebar
Funn Fatboy AL7050- T73, Triple Butted, 750mm
Stem
Easton Havoc
Headset
Cane Creek Angleset EC44x EC49
Saddle
WTB Silverado Race SL
Seatpost
RockShox Reverb w/ 125mm Height Adjust, Hydraulic
