Specialized Stumpjumper FSR Expert Carbon EVO 2012
Specialized Stumpjumper FSR Expert Carbon EVO 2012 #1515334 04/11/2012 12:58
Joachim.s Offline OP
Heisann!
Er da på tide å bli kvitt min Specialized Stumpjumper FSR Expert Carbon EVO 2012 stisykkel, som kun er brukt i underkant av 1 mående! Den er dermed så å si strøken, og i topp stand.
Stumpjumper evo er en av de råeste stisykkelen du kan få tak i, Med 150mm vandring foran og bak, er den som en utfor sykkel nedover, og med sin lette karbonramme og karbonkrank, klatrer den også lett oppover.
Spesifikasjoner:
Ramme: FACT IS 9m carbon front triangle, EVO geometry, M5 alloy rear triangle, tapered HT, carbon PF30 BB, ISCG ´05, internal Command Post routing, 142mm dropouts, sealed cartridge bearing pivots, replaceable derailleur hanger, 150mm travel
Bakdemper: Fox RP23 Adaptive Logic with AUTOSAG and Boost Valve, Kashima coating, reb and separate climbing setting and custom 3-position low-speed comp adj., 197x51mm
Gaffel: Fox Factory 150, air spring, tapered steerer, comp and LO and reb adj., 15mm thru-axle, 150mm
Styrelager: 1-1/8 and 1-1/2" Threadless, Campy style upper with 1-1/2" lower bearing for tapered integrated HT, cartridge bearings
STEM: Specialized XC, 3D forged alloy, 4-bolt, 31.8mm clamp, adjustable rise, 75mm
Styre: Specialized All-Mountain low-rise bar, 7050 alloy, 720mm wide, 8º backsweep, 6º upsweep, 31.8mm
For bremse: Custom Formula The One R, hydraulic disc, tool-less FCS and reach adjust, metallic pad, SRAM compatible MiXmaster shifter mounts, S/M:180mm rotor, Others: 203mm rotor
Bak bremse: Custom Formula The One R, hydraulic disc, tool-less FCS and reach adjust, metallic pad, SRAM compatible MiXmaster shifter mounts, S/M:160mm rotor, Others: 180mm rotor
Gir foran: SRAM X7, 10-speed, S3 direct mount for DMD, bottom-pull
Gir bak: SRAM X9, 10-speed, long cage
Shifter: SRAM X9, 10-speed, trigger
Kasset: SRAM PG-1050, 10-speed, 11-36t
Kranksett: Custom SRAM carbon S-2200, 10-speed AM double, PF30 spindle, 175mm
Setepinne: Specialized Command Post BlackLite, 3 position, adjustable height w/air spring, remote operated, single bolt head 30.9mm, 125mm vandring.
Felgsett: Nesten helt nye Easton Haven 2011 + orginal forfelg følger med. ( felger brukt 2 korte turer. Og er strøkne)
Flere bilder finn annonse: http://www.finn.no/finn/torget/tilsalgs/annonse?finnkode=37515803
Størrelse på sykkelen er Large, som passer fra ca 175-190.
Kontakt pr. Joachim.schjott@getmail.no, Telefon nr. 92673299, eller PM!
Hilsen Joachim Schjøtt
Sponsorer:
Cyklon
Beach mountain GT, Crackbrothers
Burgtec
Fox
Schwalbe
2xu
Re: Specialized Stumpjumper FSR Expert Carbon EVO 2012 [Re: Joachim.s] #1515335 04/11/2012 12:58
Prisantydning: 24.500 Ink frakt.
Sponsorer:
Cyklon
Burgtec
Fox
Schwalbe
2xu
Re: Specialized Stumpjumper FSR Expert Carbon EVO 2012 [Re: Joachim.s] #1521979 17/11/2012 17:15
Førstemann med 22.500 får sykkelen! Jeg kan ta frakt.
Selges med nesten helt nye felger ( Brukt 2 turer forrige helg i danmark)
Utrolig bra sykkel, som er så å si helt strøken!
Sponsorer:
Cyklon
Burgtec
Fox
Schwalbe
2xu
