Heisann!
Er da på tide å bli kvitt min Specialized Stumpjumper FSR Expert Carbon EVO 2012 stisykkel, som kun er brukt i underkant av 1 mående! Den er dermed i veldig bra stand, med svært lite slitasje.
Stumpjumper evo er en av de råeste stisykkelen du kan få tak i, Med 150mm vandring foran og bak, er den som en utfor sykkel nedover, og med sin lette karbonramme og karbonkrank, klatrer den også lett oppover.
Spesifikasjoner:
Ramme: FACT IS 9m carbon front triangle, EVO geometry, M5 alloy rear triangle, tapered HT, carbon PF30 BB, ISCG ’05, internal Command Post routing, 142mm dropouts, sealed cartridge bearing pivots, replaceable derailleur hanger, 150mm travel
Bakdemper: Fox RP23 Adaptive Logic with AUTOSAG and Boost Valve, Kashima coating, reb and separate climbing setting and custom 3-position low-speed comp adj., 197x51mm
Gaffel: Fox Factory 150, air spring, tapered steerer, comp and LO and reb adj., 15mm thru-axle, 150mm
Styrelager: 1-1/8 and 1-1/2" Threadless, Campy style upper with 1-1/2" lower bearing for tapered integrated HT, cartridge bearings
STEM: Specialized XC, 3D forged alloy, 4-bolt, 31.8mm clamp, adjustable rise, 75mm
Styre: Specialized All-Mountain low-rise bar, 7050 alloy, 720mm wide, 8º backsweep, 6º upsweep, 31.8mm
For bremse: Custom Formula The One R, hydraulic disc, tool-less FCS and reach adjust, metallic pad, SRAM compatible MiXmaster shifter mounts, S/M:180mm rotor, Others: 203mm rotor
Bak bremse: Custom Formula The One R, hydraulic disc, tool-less FCS and reach adjust, metallic pad, SRAM compatible MiXmaster shifter mounts, S/M:160mm rotor, Others: 180mm rotor
Gir foran: SRAM X7, 10-speed, S3 direct mount for DMD, bottom-pull
Gir bak: SRAM X0, 10-speed, mid cage
Shifter: SRAM X9, 10-speed, trigger
Kasset: SRAM PG-1050, 10-speed, 11-36t
Kranksett: Custom SRAM carbon S-2200, 10-speed AM double, PF30 spindle, 175mm
Setepinne: Specialized Command Post BlackLite, 3 position, adjustable height w/air spring, remote operated, single bolt head 30.9mm, 125mm vandring.
Felg: foran Roval traverse
Bak:
Shimano Wheels Hubs MTB XTR Trail Disc Hub Rear 142x12mm M988 32h - Centre Lock
Mavic 2013 Wheels Rims MTB 26" XM819 MTB UST Rim 32h Black
DT Swiss - Workshop Only Wheels Spokes - Builds Spokes Competition Stainless DB Black 2mm-1.8mm
DT Swiss Wheels Nipples Nipple Upgrade Brass Pro-lock Black Set Per Single Wheel(DH/FR/XC)
Velox Wheels Rim Tapes Rim Tape Cloth 19mm
Dette hjulet er grunnet av at jeg hadde en vond landing, og giret kom seg inn i hjulet, så en del eiker røk, og det ble noen litt dype riper over eikefestene nede ved navet. Felgring er helt i orden, og er godt mulig hjulet kan fikses, så dette kan følge med.
Størrelse Large, som passer fra ca 175-190.
Pris, 25.000 ink frakt.
Kontakt pr. PM, Joachim.schjott@getmail.no eller Telefon nr. 92673299.
Hilsen Joachim Schjøtt
Sponsorer:
Cyklon
Beach mountain GT, Crackbrothers
Burgtec
Fox
Schwalbe
2xu
