Fulcrum Red Carbon UST hjulsett
Fulcrum Red Carbon UST hjulsett #1485110 13/09/2012 05:40
Martin-MTB Offline OP
Selges grunnet overgang til store hjul. Hjulene er kun brukt til ritt og i god stand. Svært stive hjul som passer for ryttere i alle vektklasser. Lette hjul er ikke verdt noe som helst så lenge de ikke er stive og klarer å overføre kreftene til bakken. Dette er et svært responsivt og solid hjulsett, som likevel er svært lett. Veil nypris 25.000,- Selges for 7000,- !!
(Wiggle selger disse for 17.000,-)
Top Features of the Fulcrum Red Carbon MTB Wheelset 2010
Reactivity is the key word in Red Carbon wheels which are already present on Julien Absalon's bike.
Weight: front: 630g rear: 820g
The weight of the wheels does not include the quick release, and it refers to the lightest configuration
MTB
The new top of the range Fulcrum off-road model implements advanced solutions starting from Ultra-Fit Tubeless technology through to the use of carbon fibre. And it is thanks to this composite that it has been possible to reduce the weight of the rim. Another contribution to weight reduction is also made by the reduction of eight spokes compared with Red Metal Zero wheels. Four spokes have been removed from the front wheel and four from the rear: as a result the rotating mass is reduced too.
And stability? Don't worry, the 1,450 grams of the Red Carbon wheels are an important result but Fulcrum also know that lightness is no good without strength. That's why they designed the carbon rims asymmetrically. The rear wheel sees the rim displaced to the right to recover the dish asymmetry caused by the presence of the sprocket set. At the front, the asymmetry is displaced to the disc brake side in order to obtain a wheel which is absolutely consistent when braking too.
Her er link til hjulsettet på Wiggle.co.uk
Med vennlig hilsen
Martin Haugo
Team Merida Norge
www.martinhaugo.com
martinhaugo@me.com
Re: Fulcrum Red Carbon UST hjulsett [Re: Martin-MTB] #1485589 13/09/2012 17:24
Registrert: Nov 2010
JørgenR Offline
Tåler de en tjukkas på nesten 90 kilo som meg?
JørgenR
Re: Fulcrum Red Carbon UST hjulsett [Re: JørgenR] #1488684 19/09/2012 05:37
Vil ikke kalle deg en tjukkas ICON_SMILE Ja - UTEN PROBLEM! Dette er trikkeskinner av carbon. Superstive og solide hjul. Lettere hjul finnes, men tror ikke du klarer å finne noen som er lettere OG stivere
Med vennlig hilsen
Martin Haugo
Team Merida Norge
www.martinhaugo.com
martinhaugo@me.com
Re: Fulcrum Red Carbon UST hjulsett [Re: Martin-MTB] #1490740 22/09/2012 04:45
bump
Med vennlig hilsen
Martin Haugo
Team Merida Norge
www.martinhaugo.com
martinhaugo@me.com
