Selger min Specialized stumpjumper FSR Elite, grunnet veldig lite bruk og flytting til ny leilighet med alt for liten plass.
En nydelig sykkel for bruk på sti. Sykkelen har 140/140 vandring med låsing fremme og Specialized sin geniale Brain system på bakdemperen
Sykkelen er lite brukt, da jeg har syklet mest på epicen min. Ny pris i fjor var 27 000,-
Ønsket pris er 17 000,- Pris kan diskuteres ved en kjap avgjørelse.
Kontakt meg på PM,
Mail: hakon1991@hotmail.com
eller mobil: 45863717
spesifikasjoner
FRAMEM5 manipulated alloy w/ ORE TT/DT, sealed cartridge bearing pivots, replaceable derailleur hanger, 140mm travel
REAR SHOCKSpecialized/Fox Brain Shock w/ remote Trail Tune inertia valve, Brain Fade and rebound adj., 7.75x1.9", integrated cartridge bearing shock mount
FORKFox F140 RL, air spring, alloy steerer, reb adj., LO, standard drop-outs, 140mm travel
HEADSET1 1/8" upper and lower campy style cartridge bearings for integrated alloy HT
STEM Specialized XC, 3D forged alloy, 4-bolt, 31.8mm clamp, adjustable rise
HANDLEBARSSpecialized XC-low rise bar, 7050 butted alloy, 680mm wide, 8 degree back sweep, 6 degree up, 31.8mm
FRONT BRAKE Custom Avid Elixir R SL, hydraulic disc, tool-less reach adjust, alloy backed semi-metallic pads, stainless hardware 203mm rotor
REAR BRAKE Custom Avid Elixir R SL, hydraulic disc, tool-less reach adjust, alloy backed semi-metallic pads, stainless hardware L 185mm rotor
BRAKE LEVERSCustom Avid Elixir R SL hydraulic, tool-less reach adj.
FRONT DERAILLEURSRAM X.7, 10-speed, S1 direct mount for DMD, bottom pull
REAR DERAILLEURShimano XT Shadow, 10-speed, mid cage
SHIFT LEVERSShimano SL-M660-10R SLX, 10-speed, trigger
CASSETTE Shimano HG81, 10-speed, 11-36t
CHAINKMC X10, 10-speed, w/ reuseable Missing Link, nickel plates
CRANKSETCustom SRAM Carbon S-2200, 10-speed XC Trail double,
GXP spindle, removeable spider, S: 170mm, others: 175mm
CHAINRINGS38A x 24A, carbon shift guard, 4-bolt, 104/64mm
BOTTOM BRACKET SRAM GXP, outboard bearing
RIMSCustom DT Swiss X420SL, 24mm w/ eyelets, 28/32h
FRONT HUBSpecialized Hi Lo disc, laser-etched logo, OS 24 end caps, sealed cartridge bearing, RWS, 28h
REAR HUBSpecialized Hi Lo disc, laser-etched logo, double sealed cartridge bearing, QR, 32h
SPOKESDT Swiss Champion 1.8mm (15g) stainless
FRONT TIRES-Works Purgatory, 120 TPI, 2Bliss ready aramid bead, dual compound, 26x2.2"
REAR TIRESpecialized "The Captain" Control, 60 TPI, 2Bliss ready aramid bead, dual compound, 26x2.0"
SADDLESpecialized BG Henge Comp, hollow Cr-Mo rails, 143mm width
SEATPOST2014 butted alloy, single bolt setback, 30.9mm, S/M: 350mm, others: 400mm
SEAT BINDER34.9mm clamp ID, 7050 hard annodized alloy collar w/ QR, black
