Perfekt sykkel for stisykling. Utrolig hvordan det kommer seg frem overalt. Lang vandring i front og bak-demper gir svært god kontroll over ulendt terreng, som selvsagt kan stives opp når du skal oppover. I tillegg så er det et bredt styre og en solid ramme som gjør det svært lett å få flyten nedover stiene.
Det er 2009 mod. str: Large.
Nypris: 24900,-
Video av sykkel:
Video av sykkelen
Speks:
Color(s): Black Nickel
* Frame: Mongoose FreeDrive All Mountain/Free Ride, 165mm travel, 135mm vertical drop outs
* Fork: Marzocchi 55 ATA Micro 125-165 travel adjust, micro compression adjust, nickel stanchions, air spring with progressive bottom out, 20 mm QR thru axle
* Rear Shock: Marzocchi ROCO Air R, 5 position compression, bottom out resistance, oversize air can, and rebound adjust, 216x63 mm w/ 19x8 mm hardware
* Crankset: Shimano SLX 22/36T/BASH Hollow Tech II
* Bottom Bracket: Shimano external bearing
* Pedals: Crank Bros. Acid
* Front Derailleur: Shimano SLX for 22/36T combo
* Rear Derailleur: Shimano XT, Shadow mount
* Shifters: Shimano SLX 18 speed
* Freewheel: SRAM PG-950 Cassette11-34T
* Chain: Shimano HG73
* Rims: No Tubes ZTR Flow 32 hole
* Front Hub: Formula sealed bearing 15 mm thru axle
* Rear Hub: Formula sealed bearing cassette
* Spokes: DT Competition double butted with alloy nipples
* Brake Levers: Hayes Stroker Trail w/ tool free reach adjust
* Handlebar: Gravity Light, triple butted and shot peened AL7050, 31.8x 25x710 mm
* Stem: Gravity Light, 31.8x50 mm
* Grips: Mongoose Lock on
* Saddle: SDG Bel Air RL cromoly rail
* Seat Post: Cobra R adjustable height w/ remote 31.6 x 350 mm
Redigert av Andershl; 18/06/2012 19:11.
