Låst ipad
Låst ipad #1398373 14/05/2012 18:58
Freakout Offline OP
Min mor har skaffet seg iPad, og jeg hjalp henne med å lage en kode. Problemet er at hun nå har glemt koden og har bare 2 forsøk igjen før den deaktiveres helt. Hun har ikke syncet med PC, ellers hadde det vært easy fix.
Alternativer? What to do?!
Re: Låst ipad [Re: Freakout] #1398823 15/05/2012 09:11
Registrert: May 2011
Den glade amatør Offline
Du kan jo bare koble den til PC´n og kjøre en restore, slik at fabrikkinnstillingene blir gjennopprettet?
Eller er det selve innholdet du/hun tenker på?
"How to Unlock an iPad with a Passcode
The only way to unlock an iPad with a passcode, other than entering the passcode, is to "restore" it to its original factory settings.
To restore your iPad -- which deletes all of your data (songs, photos, videos, apps, and so on) on the iPad use the following directions. Be absolutely sure that you have backed up the content on your iPad before restoring it.
Apple's official instructions to restore an iPad are:
1. Connect iPad to your computer.
2. Select iPad in the iTunes sidebar, then click the Summary tab.
3. Click “Check for Update.” iTunes tells you if there’s a newer version of the iPad software available.
4. Click Restore. Follow the onscreen instructions to complete the restore process. When restoring, it is recommended that you back up iPad when prompted. When the iPad software has been restored, you can choose to set up iPad as a new iPad, or restore your music, videos, app data, and other content from a backup.
Please additionally note that Apple staff also cannot unlock an iPad for you without restoring the iPad, which will erase everything on it. "
Re: Låst ipad [Re: Freakout] #1398838 15/05/2012 09:31
Og neste gang du legger inn passord, må du ikke sette maks antall ganger før den låser seg helt.
Re: Låst ipad [Re: baronKanon] #1398874 15/05/2012 10:07
perbl Offline
Låser den seg da? Jeg trodde den automatisk slettet alt jeg.
Re: Låst ipad [Re: Freakout] #1398924 15/05/2012 11:01
Freakout Offline OP
Den er ikke syncet med PC, ellers så hadde det vært easy fix, som jeg sa i første post. Nye iPader MÅ ikke bli koblet til pc for å fungere, de funker rett ut av boksen.
iPaden vet jo ikke om det er en tyv eller eieren som taster feil kode.
Re: Låst ipad [Re: Freakout] #1399272 15/05/2012 19:40
Freakout Offline OP
Eplehuset fikset det! Reininstallerte alt.
