Veldig pent brukt 2011 Boot'R Foreman DH i størrelse Large selges - kun brukt 1 dag i Åre!
Nypris: 25.000,-
Selges: 13.000,-
Ta kontakt på epost odd.arne.steffensen@gmail.com
Frame: Mongoose FreeDrive DH 210mm travel and 150mm Maxle dropouts
Fork: Rock Shox Boxxer RC 200 mm travel, rebound, compression and preload adjust, 20 mm Maxle thru axle
Rear Shock: Fox Van R rebound and preload adjust, 241x76 mm w/ 19x8 mm hardware
Crank: Truvativ Hussefelt with cromoly pedal inserts 38T ring
Bottom Bracket: Truvativ Howitzer TM (83 mm shell)
Shifters: SRAM X.7 9 speed
Speeds: 9 Speed
Cog Set: SRAM PG-950 Cassette 11-26
Rear Derailleur: SRAM X.9 short cage
Rims: SUN MTX-31 32 hole
Tires: Kenda Excavator DH w/ Stick-E rubber 26X2.5
Pedals: Funn melt forged with 3M mini panel and replaceable pins
Brakes: Avid Code R four piston caliper, 203 mm front rotor / 185 mm rear rotor
Handlebar: Funn Fatboy butted 7050AL riser 31.8x50x710 mm
Stem: FUNN RSX 31.8x45 mm direct attach for Boxxer, CNC alloy
Extras: MRP G2 chainguide
Redigert av OddArne; 21/04/2012 10:22.
Importør av GT, Haibike, Diavelo, Charge og Mongoose
