Dette er en superduper versjon av legendarisk freeridesykkel / utforsykkel. Meget spesiell ramme, antagelig eneste i Norge, selges på grunn av overgang til 2011 Demo 8II.
2007 modell, str S - i meget god stand - MÅ SES.
Pris: 11 000,-
Sykkelen vises og selges i Oslo. Kan unntaksvis sendes.
Kan kontaktes på:
simen@bergphoto.net
9172 4343
Spesifikasjon:
- Kjøpt som ramme - utstyrt som Demo 7I.
- Nytt styrelager og nye hjullagre.
- Soft fjær til gaffel følger med.
Se også:
http://www.specialized.com/us/en/bc/SBCProduct.jsp?arc=2007&spid=21990 FRAME: Demo 7 FSR M5 manipulated alloy, 7" travel, 26" F/R wheel, asymetrical rear triangle, ISCG mount, adj geometry, 1.5" forged HT, cartridge bearing rear shock mount, rear derailleur protector
REAR SHOCK: Fox DHX 5.0 coil, adjustable rebound, ProPedal, IFP pressure
FORK: RockShox Totem Coil for Specialized, custom Black Box speed stack damper, adj comp and reb, 180mm travel, alloy 1.5" steerer, 20mm thru-axle w/ Maxle
HEADSET: FSA Extreme Pro 1 1/2" with sealed bearings
STEM: Truvativ Holzfeller 1.5", 31.8 clamp, 40mm
HANDLEBARS: Specialized Demo rise bar, 6066 alloy, 31.8mm, 6 degree up, 9 degree backsweep, 680mm width
TAPE/GRIPS: Specialized MTB, dual density
FRONT BRAKE: Avid Juicy 5, hydraulic disc, G2 Clean Sweep 200mm rotor
REAR BRAKE: Avid Juicy 5, hydraulic disc, G2 Clean Sweep 200mm rotor
BRAKE LEVERS: Avid Juicy 5
REAR DERAILLEUR: SRAM X-9, 9-speed, short cage
SHIFT LEVERS: SRAM X-7, aluminum trigger 9-speed
CASSETTE/FREEWHEEL: Shimano HG50, 9-speed, 11/34t
CHAIN: SRAM PC-951 w /Power Link
CRANKSET: Truvativ Holzfeller, 36t alloy ring, 170mm, w/ Gamut guide
CHAINRINGS: 36t, 4 bolt, compact 104mm pattern
BOTTOM BRACKET: Truvativ Howitzer Team, oversize sealed outboard cartridge bearing, 73mm shell
PEDALS: selges uten pedaler
RIMS: Specialized E450, 28mm w/eyelets, 36h
FRONT HUB: Specialized disc, 20mm thru axle, 36h
REAR HUB: Specialized bolt-on 135mm, hollow Cro-Mo axle w/ RD guard
SPOKES: DT Swiss 2.0
FRONT TIRE: Maxxis DHf Minion
REAR TIRE: Maxxis DHf Minion
SADDLE: Specialized Enduro, 8mm hollow Cro-Mo rails, SL foam
SEAT POST: Thomson SPE127/8
SEAT BINDER: 7050 hard annodized alloy collar w/ QR, 34.9mm clamp ID, black
http://www.specialized.com/us/en/bc/SBCProduct.jsp?arc=2007&spid=21990Det tas forbehold om feil i spesifikasjonene.
