Specialized Demo 7 II 2008 SOLGT
Specialized Demo 7 II 2008 SOLGT #1354769 19/03/2012 23:46
simenberg Offline OP
Leken og god freeride / utforsykkel med 180 mm vandring, str Medium (selger er 187 cm). Selges pga. overgang til Demo 8. Kjøpt som ramme - utstyrt som Demo 7 I (2007 setup). Har naturligvis bruksmerker etter noen års bruk, men sykkelen har mange gode år igjen.
Pris 10 000,-
Tlf 9172 4343 eller simen@bergphoto.net
Nytt hjullager bak. Jevnlig servet gaffel, nye innerbein i 2010.
Avvik fra standard oppsett på Demo 7 I
- XO bakgir
- Juicy 7 bremser
- Bredt styre
- 38t krankdrev
Spesifikasjoner:
FRAME: Demo 7 FSR M5 manipulated alloy, 7" travel, 26" F/R wheel, asymetrical rear triangle, ISCG mount, adj geometry, 1.5" forged HT, cartridge bearing rear shock mount, rear derailleur protector
REAR SHOCK: Fox DHX 5.0 coil, adjustable rebound, ProPedal, IFP pressure
FORK: RockShox Totem Coil for Specialized, custom Black Box speed stack damper, adj comp and reb, 180mm travel, alloy 1.5" steerer, 20mm thru-axle w/ Maxle
HEADSET: 1 1/2" alloy upper with OS bearings, 7050 lightweight cups
STEM: Truvativ Holzfeller 1.5", 31.8 clamp, 40mm
HANDLEBARS: Specialized 760mm
TAPE/GRIPS: Lock on ett eller annet.
FRONT BRAKE: Avid Juicy 7, hydraulic disc, G2 Clean Sweep 200mm rotor
REAR BRAKE: Avid Juicy 7, hydraulic disc, G2 Clean Sweep 200mm rotor
BRAKE LEVERS: Avid Juicy 7
REAR DERAILLEUR: SRAM X-0, 9-speed, short cage
SHIFT LEVERS: SRAM X-7, aluminum trigger 9-speed
CASSETTE/FREEWHEEL: Shimano HG50, 9-speed, 11/34t
CHAIN: SRAM PC-951 w /Power Link
CRANKSET: Truvativ Holzfeller, 36t alloy ring, 170mm, w/ Gamut guide
CHAINRINGS: 38t, 4 bolt
BOTTOM BRACKET: Truvativ Howitzer Team, oversize sealed outboard cartridge bearing, 73mm shell
PEDALS: selges uten pedaler
RIMS: Specialized E450, 28mm w/eyelets, 36h
FRONT HUB: Specialized disc, 20mm thru axle, 36h
REAR HUB: Specialized bolt-on 135mm, hollow Cro-Mo axle w/ RD guard
SPOKES: DT Swiss 2.0
FRONT TIRE: Maxxis DHF Minion
REAR TIRE: Maxxis DHF Minion
SADDLE: Specialized sort
SEAT POST: Thomson SPE127/8
SEAT BINDER: 7050 hard annodized alloy collar w/ QR, 34.9mm clamp ID, black
2007 Demo 7 I spek:
http://www.specialized.com/us/en/bc/SBCProduct.jsp?arc=2007&spid=21988
2008 Demo 7 II ramme/shock:
http://www.specialized.com/us/en/bc/SBCProduct.jsp?arc=2008&spid=34365
Sykkelen vises og selges i Oslo. Kan unntaksvis sendes.
Det tas forbehold om feil i spesifikasjonene.
Samme sted selges Demo 7 II i Small. Kjerringkjørt og strøken.
http://terrengsykkel.no/ubb/ubbthreads.php?ubb=showflat&Number=1355044
Redigert av simenberg; 23/03/2012 23:45. Rediger grunn: Solgt
Selger Spesh Turbo Levo i XLarge
2022 Specialized Levo | 2012 RM Flatline WC | 2016 Trek Powerfly 7+
facebook.com/SimenBergPhotography
Re: Specialized Demo 7 II 2008 [Re: simenberg] #1354776 20/03/2012 00:13
JonahHex Offline
Leppedefekt kåbbåj
Leppedefekt kåbbåj
Sikkert medium denne også? Leter etter sykkel til guttungen - 192cm og 100kg
Re: Specialized Demo 7 II 2008 [Re: simenberg] #1354779 20/03/2012 00:36
Det stemmer, tipper den blir litt for liten.
Re: Specialized Demo 7 II 2008 [Re: simenberg] #1355588 20/03/2012 22:34
Flere bilder fra jomfruturen. Kommer til å savne det ryddige rammedesignet på denne sykkelen. Se spek over for dagens setup.
Re: Specialized Demo 7 II 2008 SOLGT [Re: simenberg] #1357859 23/03/2012 23:56
Sykkelen er solgt.
Har fortsatt nevnte Small til salgs:
http://terrengsykkel.no/ubb/ubbthreads.php?ubb=showflat&Number=1293139
