Splitter nye Sidi Ergo 3 2012 Speedplay edition
Splitter nye Sidi Ergo 3 2012 Speedplay edition #1297926 15/11/2011 19:04
Registrert: Dec 2009
faandrem Offline OP
Selger neste års racertoppmodell fra Sidi. Skoene er ikke på markedet i Norge enda. Helt ny såle spesiallaget for Speedplay. Str 43. Selges på grunn av feil størrelse. Følger med skopose
Ta kontakt på PM eller mobil 93026980
Selges for 3400,- ved rask avgjørelse . Kjøper betaler frakt.
Helt strøkne, se bilder. Kan sende flere.
NEW Sidi Ergo 3 SP Carbon Sole® is SPEEDPLAY APPROVED for superior power transfer, reduced set-up weight, ergonomics and ease of installation. Redesigned Adjustable Heel Retention Device® increases airflow, reduces weight. Lower cut, wider design and softer, more compliant material improves ergonomics. Patented Techno II Buckle System and Caliper Buckle for easy on-bike fit adjustment. Soft Instep Closure System® and padded tongue eliminate pressure points. Dual density insoles and high security velcro® won’t shift or slip.
SPEEDPLAY APPROVED for superior ergonomics, power transfer, light weight and ease of set-up
Ergonomics: Direct interface between the Speedplay cleat and the shoe brings the rider 3mm closer to the pedal
Power Transfer: Direct interface between the Speedplay cleat and the shoe improves lateral rigidity
Light weight: Speedplay cleat set-up weight is reduced by 200 grams per pair (almost a quarter pound)
Easy Set-Up: The SP Carbon Sole® eliminates the need for four-bolt adapters
Color: White Vernice
Re: Splitter nye Sidi Ergo 3 2012 Speedplay edition [Re: faandrem] #1299188 17/11/2011 18:29
faandrem Offline OP
utilgjengelige
