Raceface Atlas krank fresh from the box
Raceface Atlas krank fresh from the box #1234813 13/08/2011 20:05
yoo Offline OP
Selger denne splitter nye atlas kranken til 1000,-
kontakt pm. eller mobil 98029565
Re: Raceface Atlas krank fresh from the box [Re: yoo] #1234890 13/08/2011 22:44
Nikkern Offline
Hvor bestilte du den?
Re: Raceface Atlas krank fresh from the box [Re: Nikkern] #1236180 15/08/2011 16:21
yoo Offline OP
selger den for en kompis:)
Redigert av yoo; 15/08/2011 16:21.
Re: Raceface Atlas krank fresh from the box [Re: yoo] #1236218 15/08/2011 17:15
yoo Offline OP
passer for 83mm krankhus
Re: Raceface Atlas krank fresh from the box [Re: yoo] #1236223 15/08/2011 17:17
torzen Offline
åsså er det 175mm armer på den :-)
Re: Raceface Atlas krank fresh from the box [Re: torzen] #1237257 16/08/2011 18:50
yoo Offline OP
true.
Re: Raceface Atlas krank fresh from the box [Re: yoo] #1238345 17/08/2011 20:51
gtv Offline
Type lager og bredde på krankhus?
Orbea Wild FS
Devinci Atlas Karbon
Cannondale Flash 29"
Felt Nine Race 29" custom
When you stop doing things for fun you might as well be dead
Re: Raceface Atlas krank fresh from the box [Re: gtv] #1239702 19/08/2011 09:23
yoo Offline OP
Bredde er som sagt 83mm og du kan bruke følgende lager: (kopi fra tråd på pinkbike)Shimano's Hollowtech II and Race Face's X-Type bottom bracket standard is the same - the bottom brackets are interchangeable
you can run your atlas crank with any bottom bracket from Hope, Chris King, etc. that is compatible with HT2 or X-Type cranks
I am running Race Face Deus cranks with Shimano M660 HT2 bottom bracket on my commuting bike
Truvativ's Howizter is a different standard and the bottom brackets are incompatible with HT2 / X-Type
FSA also have different standards depending on their crank model, but generally they are incompatible with HT2 / X-Type
if you want a good, tough and cheap HT2 / X-Type bottom bracket, I'd strongly recommend the Shimano HT2 M660 type
Redigert av yoo; 19/08/2011 09:24.
Re: Raceface Atlas krank fresh from the box [Re: yoo] #1244095 24/08/2011 07:48
yoo Offline OP
Bump
Re: Raceface Atlas krank fresh from the box [Re: yoo] #1251088 01/09/2011 10:14
yoo Offline OP
BUMP!
