Spesifikasjoner Sykkeltype: Terreng Beskrivelse Sykkel er veldig lite brukt og fremstår så å si som ny! Sykkelen kan ses i Oslo, veilprisen på sykkelen er 40000,- størrelse Medium
spesifikasjoner:
Frame: Suspension Fork: Manitou Dorado Pro, inverted 7050 alloy legs, 203 mm travel, TPC+ damping with high/low compression, rebound, low pressure air spring, Hex Thru Axle Rear Shock: Elka Stage 5, high/low compression and rebound adjust, 241x76 mm w/ 19x8 mm hardware Rims: SUN MTX-31 32 hole Hubs: Formula sealed bearing 20mm thru axle Spokes: DT Champion 14G stainless Tires: Kenda Excavator DH w/ Stick-E rubber 26X2.5 Pedals: FUNN Sol Jam Viper Crankset: Funn Hooka DH 38T ring Bottom Bracket: Truvativ Howitzer TM (83 mm shell) Chain: KMC X9 w/ Missing Link connector Cog set: SRAM PG-950 Cassette 11-26 Front Derailleur: N/A Rear Derailleur: SRAM X.O short cage Shifters: SRAM X.0 trigger 9 speed Handlebar: Funn Fatboy butted 7050AL riser 31.8x50x710 mm Stem: FUNN RSX 31.8x45 mm direct attach for Boxxer, CNC alloy Headset: FSA Orbit Z 1.5 Flush Fit, reduces 1.5 head tube to 1 1/8" fork Brake Rotor: Avid Code R four piston caliper, 203 mm front rotor / 185 mm rear rotor Brake Levers: Avid Code R Saddle: Funn Skinny RL Seat Post: Funn, 31.6x250 Extras: MRP G2 chainguide Rock Shox Maxle Front Hub: Formula sealed bearing 20mm thru axle Rear Hub: Formula sealed bearing 150x12 thru axle cassette
Nytter ikke sende melding her inne, enten per sms eller mail: geir.norland@gmail.com 98219495
