Cannondale Flash HT kjøpes:
Cannondale Flash HT kjøpes: #1207541 30/06/2011 15:34
Ronson Offline OP
Hei jeg ønsker å kjøpe en Cannondale Flash HT str. L/ XL
Send meg gjerne en PM om du har en til salgs.
Ronnie
Re: Cannondale Flash HT kjøpes: [Re: Ronson] #1207690 30/06/2011 19:49
Registrert: Oct 2008
esb-r Offline
Hei.
Har en Flash F1 i Large.
Sykkelen er modifisert med ny XTR krank og Mavic SLR hjulsett.
Farge hvit, kjøpt ny i september i fjor og brukt ca 80 mil.
Denne vil jeg ha ca 18000,- for.
Mvh Esben Rød.
Frame: Flash alloy S.A.V.E. BB30 w/ 1.5" HeadShok head tube
Fork: Lefty Speed alloy DLR 110mm Solo Air w/ one-piece outer
Rims: DT Swiss XCR 1.7
Hubs: DT Swiss XCR 1.7
Spokes: DT Swiss XCR 1.7
Tires: Schwalbe Racing Ralph 2.1" EVO Triple Nano
Pedals: Shimano M520 clipless
Crank: Truvativ Stylo OCT 3.3 44/32/22t
BottomBracket: included with crank
Chain: SRAM PC-951 9sp
RearCogs: SRAM PG-970 11-32t 9sp
FrontDerailleur: Shimano SLX
RearDerailleur: SRAM X-0
Shifter: SRAM X-9 triggers
Handlebar: Cannondale C3 flat
Stem: Cannondale SI stem/steerer 3D forged
Headset: Cannondale SI HeadShok
Brakes: Avid Elixir R
BrakeLevers: Avid Elixir R Carbon
Saddle: new Cannondale Stage w/ crmo rails
Seatpost: Cannondale C3 31.6mm w/ 15mm offset
Sizes: S,M,L,X,J
Extras: new Cannondale LE SuperLight lock-on grips
Re: Cannondale Flash HT kjøpes: [Re: esb-r] #1207796 30/06/2011 21:56
Ronson Offline OP
Takk for svar!, jeg burde ha spesifisert bedre;
Ønsker kun Team/ Ultimate versjonen (karbon).
Ronnie
Re: Cannondale Flash HT kjøpes: [Re: esb-r] #1209246 03/07/2011 19:27
campafanatic Offline
Hei
Har en Cannondale Flash Himod i str xl
Specs som følger:
Ramme: Cannondale Flash Team Edition 2010 XL
Gaffel: Lefty Speed Carbon SL 110mm Solo Air OPI
Krank: Cannondale Hollowgram SL crank XX Spider 42/28T
Bremser: Formula R1 160/140
Drivverk:
SRAM XX direct mount FD
SRAM XX triggers
SRAM XX RD
SRAM XX 11-36 cassette
SRAM PC 1090r chain
Hjulsett: Shimano XTR Lefty
Stem: Stem XC3 2011 110 og 120 mm
Styre:Ritchey Superlogic low riser 31.8mm / 660mm handlebar ( cut to 640mm)
Som du ser av spec så er dette en sykkel som er satt opp som en team edition. Med Formula R1 bremser istedet for xx bremser(mange ser dette so en oppgradering). Har derimot ikke hjulsettet fra DT Swiss som følger teameditionen, her kan du eventuelt oppgradere etter eget ønske.
Er offshore nå, kommer på land på Tirsdag, Du kan ringe meg da hvis du er interessert.
Tlf: 90553327
Cannondale Flash 29er HM1
Cannondale Supersix Evo
Cannondale CAAD9 CX
Tacx Genius
